vue: 使用ts-loader引入ts文件
彭世瑜 发表于 2021/08/13 22:33:11 2021/08/13
【摘要】 安装 npm install typescript ts-loader --save-dev 1 vue.config.js configureWebpack: { resolve: {extensions: [".ts", ".tsx", ".js", ".json"]}, module: { rules: [ { test: /\.ts$/, load...
安装
vue.config.js
configureWebpack: {
  module: { rules: [ { test: /\.ts$/, loader: "ts-loader" }, ]
tsconfig.json
  "compilerOptions": { "target": "es5", "module": "commonjs", "noImplicitAny": true, "removeComments": true, "preserveConstEnums": true, "sourceMap": false
  "include": ["src/**/*"],
  "exclude": ["node_modules","**/*.spec.ts"]
报错
Syntax Error: TypeError: loaderContext.getOptions is not a function
原因:
ts-loader 9 不支持 webpack 4
换一个版本
npm install ts-loader@8.2.0
参考:
https://github.com/TypeStrong/ts-loader/issues/595
原文链接:pengshiyu.blog.csdn.net/article/details/116653235
