Backbone.js:为复杂WEB应用程序提供MVC结构
彭世瑜 发表于 2021/08/14 00:27:51 2021/08/14
【摘要】 文档: doc: https://backbonejs.org/doc-zh: https://www.backbonejs.com.cn/ Backbone依赖: jqueryunderscore 使用示例 <!-- 引入依赖 --> <script src="https://cdn.bootcdn.net/ajax/libs/jquer...
文档:
  • doc: https://backbonejs.org/
  • doc-zh: https://www.backbonejs.com.cn/
Backbone依赖:
  • jquery
  • underscore
使用示例
<!-- 引入依赖 -->
<script src="https://cdn.bootcdn.net/ajax/libs/jquery/3.6.0/jquery.min.js"></script>
<script src="https://cdn.bootcdn.net/ajax/libs/underscore.js/1.13.0/underscore-umd-min.js"></script>
<script src="https://cdn.bootcdn.net/ajax/libs/backbone.js/1.4.0/backbone-min.js"></script>
<!-- html -->
<div id="container"></div>
<!-- script -->
<script type="text/javascript">
  var AppView = Backbone.View.extend({ el: "#container", // 创建后执行 initialize: function () { this.render(); }, render: function () { this.$el.html("<h1>Hello World!</h1>"); },
  }); var appView = new AppView();
</script>
  • 26
  • 27
  • 28
  • 29
  • 30
渲染结果
<div id="container"><h1>Hello World!</h1></div>
参考
w3cschool-backbonejs 教程
原文链接:pengshiyu.blog.csdn.net/article/details/116930890
