PHP:firebase/php-jwt生成jwt和验证
彭世瑜 发表于 2021/08/13 23:06:25 2021/08/13
【摘要】 安装 composer require firebase/php-jwt 1 文档:https://github.com/firebase/php-jwt <?php require __DIR__ . '/../vendor/autoload.php'; use Firebase\JWT\JWT; use Firebase\JWT\ExpiredEx...
安装
<?php
use Firebase\JWT\ExpiredException;
$key = "example_key";
$time = time();
$data = [
  'id'=>  1,
  'username'=> 'Tom'
$payload = array( "iat" => $time, // 签发时间 "ext" => $time, // 过期时间 "data"=> $data  // 携带数据
$jwt = JWT::encode($payload, $key);
echo $jwt;
// 正常的jwt
$decoded = JWT::decode($jwt, $key, array('HS256'));
print_r($decoded);
//[iat] => 1622605592
//[ext] => 1622605592
//[data] => stdClass Object
// [id] => 1
// [username] => Tom
// 异常捕获
$jwt = 'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpYXQiOjE2MjI2MDUzNDUsImV4dCI6MTYyMjYwNTM0NSwiZGF0YSI6eyJpZCI6MSwidXNlcm5hbWUiOiJUb20ifX0.Jgp1JBPngj0lgmFpMty7C76mWwtFQVoLvQtGsN5LcpgstdClass Object';
try { $decoded = JWT::decode($jwt, $key, array('HS256'));
}catch (ExpiredException $e){ echo 'token已过期';
}catch (\Exception $e){ echo 'token无效';
print_r($decoded);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
参考
thinkphp6集成JWT
原文链接:pengshiyu.blog.csdn.net/article/details/117464356
