PHP:将list列表转为tree树形数据
彭世瑜 发表于 2021/08/14 00:48:04 2021/08/14
【摘要】 采用递归将数据列表转换成树 $list = [ ["id" => 1, "name" => "头条", "parent_id" => 0], ["id" => 2, "name" => "快讯", "parent_id" => 0], ["id" => 3, "name" => "情感", "parent_id" =&g...
采用递归将数据列表转换成树
$list = [ ["id" => 1, "name" => "头条", "parent_id" => 0], ["id" => 2, "name" => "快讯", "parent_id" => 0], ["id" => 3, "name" => "情感", "parent_id" => 2], ["id" => 4, "name" => "成人", "parent_id" => 3]
 * 采用递归将数据列表转换成树
 * @param $dataArr 数据列表
 * @param int $rootId 根节点ID
 * @param string $pkName 主键名
 * @param string $pIdName 父节点id名
 * @param string $childName  子节点名称
 * @return array
function ListToTreeRecursive($dataArr, $rootId = 0, $pkName = 'id', $pIdName = 'parent_id', $childName = 'children')
{ $arr = []; foreach ($dataArr as $sorData) { if ($sorData[$pIdName] == $rootId) { $children = ListToTreeRecursive($dataArr, $sorData[$pkName]); if($children){ $sorData[$childName] = $children; } $arr[] = $sorData; } } return $arr;
$tree = ListToTreeRecursive($list);
echo json_encode($tree, JSON_UNESCAPED_UNICODE);
  • 26
  • 27
  • 28
  • 29
[ { "id":1, "name":"头条", "parent_id":0 }, { "id":2, "name":"快讯", "parent_id":0, "children":[ { "id":3, "name":"情感", "parent_id":2, "children":[ { "id":4, "name":"成人", "parent_id":3 } ] } ] }
  • 26
参考
PHP List数据集/数组转换成树状结构Tree
原文链接:pengshiyu.blog.csdn.net/article/details/117511179
