Unity 之 编辑器模拟手机大退重连工具类
陈言必行 发表于 2021/08/13 22:19:41 2021/08/13
【摘要】 分享一个曾经用过的在Unity Editor 上模拟小断线的重连的工具类(手机大退再回来),复制代码到你的工程中,然后挂载到任意物体;运行后,即可模拟断线重连了。 源码如下: using UnityEditor; using UnityEngine; public class SwitchToBackground : MonoBehaviour { public ...
源码如下:
using UnityEditor;
using UnityEngine;
{ public void sendApplicationPauseMessage(bool isPause) { Transform[] transList = GameObject.FindObjectsOfType<Transform>(); for (int i = 0; i < transList.Length; i++) { Transform trans = transList[i]; //Note that messages will not be sent to inactive objects trans.SendMessage("OnApplicationPause", isPause, SendMessageOptions.DontRequireReceiver); } } public void sendApplicationFocusMessage(bool isFocus) { Transform[] transList = GameObject.FindObjectsOfType<Transform>(); for (int i = 0; i < transList.Length; i++) { Transform trans = transList[i]; //Note that messages will not be sent to inactive objects trans.SendMessage("OnApplicationFocus", isFocus, SendMessageOptions.DontRequireReceiver); } } public void sendEnterBackgroundMessage() { sendApplicationPauseMessage(true); sendApplicationFocusMessage(false); } public void sendEnterFoegroundMessage() { sendApplicationFocusMessage(true); sendApplicationPauseMessage(false); }
[CustomEditor(typeof(SwitchToBackground))]
public class simulateSwitchToBackgroundEditor : Editor
{ void OnEnable() { } public override void OnInspectorGUI() { DrawDefaultInspector(); serializedObject.Update(); serializedObject.ApplyModifiedProperties();//now varibles in script have been updated   if (GUILayout.Button("send enter background message")) { if (Application.isPlaying) { ((SwitchToBackground)target).sendEnterBackgroundMessage(); } } if (GUILayout.Button("send enter foeground message")) { if (Application.isPlaying) { ((SwitchToBackground)target).sendEnterFoegroundMessage(); } } }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
挂载带场景任意物体上即可。。。
1.0
PS:一个需要注意的点,打包时需要将代码全部注释,重新编译后重新尝试打包即可,否则会报错,
1.1
文章来源: czhenya.blog.csdn.net,作者:陈言必行,版权归原作者所有,如需转载,请联系作者。
原文链接:czhenya.blog.csdn.net/article/details/110188563
