webpack:自定义loader
【摘要】 以下是一个自定义loader replace-loader,实现一个类似模板引擎变量替换的简单功能
文件目录
├── dist
│ └── index.js # 打包结果
├── loaders
│ └── replace-loader.js # 自定义loader
├── src
│ └── index.js # 要打包的文件入口
├── pa...
文件目录
├── dist
├── loaders
├── src
├── package.json # 依赖配置
└── webpack.config.js # 打包配置
package.json
"name": "loader-demo",
"version": "1.0.0",
"description": "a webpack loader demo",
"scripts": { "build": "webpack"
}, "devDependencies": { "loader-utils": "^2.0.0", "webpack": "^5.47.0", "webpack-cli": "^4.7.2"
webpack.config.js
'use strict';
const path = require('path');
module.exports = {
// 打包入口
entry: { index: './src/index.js',
}, // 指定输出地址及打包出来的文件名
output: { path: path.join(__dirname, 'dist'), filename: '[name].js',
}, // Loader路径
resolveLoader: { modules: ['node_modules', './loaders'],
}, module: { rules: [ { test: /.js$/, use: { loader: 'replace-loader', // 传递参数 options: { name: 'Tom', }, }, }, ],
}, // 开发环境
mode: 'production',
loaders/replace-loader.js
const loaderUtils = require('loader-utils');
module.exports = function (source) {
// 获取参数
let options = loaderUtils.getOptions(this); for (let [key, value] of Object.entries(options)) { source = source.replace(`{{${key}}}`, value);
} return source;
src/index.js
console.log('hi {{name}}');
指定打包命令
$ npm run build
dist/index.js
console.log("hi Tom");
原文链接:pengshiyu.blog.csdn.net/article/details/119173501
cloudbbs@huaweicloud.com
