source to install ansible
JBo 发表于 2021/08/12 09:22:24 2021/08/12
【摘要】 source to install ansible ansible source to install ansible ansible====== 源码安装ansible ====== 建议升级python版本到2.6以上. 不然运行会出错或者有些功能会没有,在编译安装其他包的时候也会因为兼容问题报错。# yum install zlib zlib-devel》》 python2.7安...
ansible
  建议升级python版本到2.6以上.
》》 python2.7安装
https://www.python.org/ftp/python/2.7.12/Python-2.7.12.tgz
  # wget https://www.python.org/ftp/python/2.7.12/Python-2.7.12.tar.xz --no-check-certificate
  # tar xvzf Python-2.7.12.tgz
  # cd Python-2.7.12
  # ./configure --prefix=/usr/local
  # make
  # make install
  ## 将python头文件拷贝到标准目录,以避免编译ansible时,找不到所需的头文件
  # cd /usr/local/include/python2.7.12
  # cp -a ./* /usr/local/include/
  ## 备份旧版本的python,并符号链接新版本的python
  # cd /usr/bin
  # mv python python.old
  # ln -s /usr/local/bin/python2.7 /usr/local/bin/python
  # rm -f /usr/bin/python && cp /usr/local/bin/python2.7 /usr/bin/python
  ## 修改yum脚本,使其指向旧版本的python,已避免其无法运行
  # vim /usr/bin/yum
  #!/usr/bin/python  -->  #!/usr/bin/python2.6
》》setuptools模块安装
  # wget https://pypi.python.org/packages/source/s/setuptools/setuptools-7.0.tar.gz --no-check-certificate
  # tar xvzf setuptools-7.0.tar.gz
  # cd setuptools-7.0
  # python setup.py install
安装好setuptools后就可以利用easy_install这个工具安装
》》 pycrypto模块安装
  # wget https://pypi.python.org/packages/source/p/pycrypto/pycrypto-2.6.1.tar.gz --no-check-certificate
  # tar xvzf pycrypto-2.6.1.tar.gz
  # cd pycrypto-2.6.1
》》 PyYAML模块安装
  # wget http://pyyaml.org/download/libyaml/yaml-0.1.5.tar.gz --no-check-certificate
  # tar xvzf yaml-0.1.5.tar.gz
  # cd yaml-0.1.5
  # make --jobs=`grep processor/proc/cpuinfo | wc -l`
  # make install
》》 PyYAML
  # wget https://pypi.python.org/packages/source/P/PyYAML/PyYAML-3.11.tar.gz --no-check-certificate
  # tar xvzf PyYAML-3.11.tar.gz
  # cd PyYAML-3.11
》》 Jinja2模块安装
  # wget https://pypi.python.org/packages/source/M/MarkupSafe/MarkupSafe-0.9.3.tar.gz --no-check-certificate
  # tar xvzf MarkupSafe-0.9.3.tar.gz
  # cd MarkupSafe-0.9.3
》》 Jinja
  # wget https://pypi.python.org/packages/source/J/Jinja2/Jinja2-2.7.3.tar.gz --no-check-certificate
  # tar xvzf Jinja2-2.7.3.tar.gz
  # cd Jinja2-2.7.3
》》 Paramiko模块安装
  # wget https://pypi.python.org/packages/source/e/ecdsa/ecdsa-0.11.tar.gz --no-check-certificate
  # tar xvzf ecdsa-0.11.tar.gz
  # cd ecdsa-0.11
》》 Paramiko
  # wget https://pypi.python.org/packages/source/p/paramiko/paramiko-1.15.1.tar.gz --no-check-certificate
  # tar xvzf paramiko-1.15.1.tar.gz
  # cd paramiko-1.15.1
》》 simplejson模块安装
  # wget https://pypi.python.org/packages/source/s/simplejson/simplejson-3.6.5.tar.gz --no-check-certificate
  # tar xvzf simplejson-3.6.5.tar.gz
  # cd simplejson-3.6.5
》》 ansible安装
  # wget https://github.com/ansible/ansible/archive/v1.8.4.tar.gz --no-check-certificate
  # tar xvzf ansible-1.8.4.tar.gz
  # cd ansible-1.8.4
安装 openssl,这一步是为了安装pip,不然安装pip的时候会报错
# yum install openssl openssl-devel
安装 readline-devel,不然在python命令行中使用方向键会识别成^[[D ^[[A等字符,导致无法使用
# yum install readline-devel
在升级了python之后,原来的sqlite也会变得不可用,需要重新安装。
安装 python-sqlite2,这个包是python与sqlite的接口
# yum install python-sqlite2.x86_64
安装 sqlite-devel,为了python可以正常使用sqlite
# yum install sqlite-devel
回到python目录下重新编译安装python
# cd /usr/local/python
# make
# make install
安装 pip,因为我们安装的是python 2.7.12,这个版本不自带pip,所以我们要手动安装。
# wget https://bootstrap.pypa.io/get-pip.py
# python ./get-pip.py
# ln -s /usr/local/python/bin/pip /usr/bin/pip
