zabbix support windows
JBo 发表于 2021/08/12 09:20:01 2021/08/12
【摘要】 zabbix support windows monitoring windows host Install program 参数含义: code zabbix support windows monitoring windows host# down file `[`http://www.zabbix.com/downloads/2.2.9/zabbix_agents_2.2.9.wi...
# down file  `[`http://www.zabbix.com/downloads/2.2.9/zabbix_agents_2.2.9.win.zip`]
# down file  `[`http://www.zabbix.com/downloads/2.2.9/zabbix_agents_2.2.9.linux2_6.i386.tar.gz`]
Install program
#   cd C:\Program Files\zabbix`\
# zabbix_agentd.exe -c "c:\Program Files\zabbix\zabbix_agentd.conf" -i  # install`\
# zabbix_agentd.exe -c "c:\Program Files\zabbix\zabbix_agentd.conf" -s  # start`\
参数含义:
-c 制定配置文件所在位置 -i 安装客户端 -s 启动客户端 -x 停止客户端 -d
卸载客户端 View server
code
Server=192.16.1.20 \# zabbix服务器ip地址
# ServerActive=192.16.1.20 \#
zabbix服务器ip地址
Hostname=win-server \# 客户端机器名 C:\\Program
Files\\zabbix-2.2.9\\sbin\>zabbix\_agentd.exe -i -c
..\\etc\\zabbix\_agentd.conf zabbix\_agentd.exe \[2304\]:
service
\[Zabbix Agent\] installed successfully zabbix\_agentd.exe \[2304\]:
event source \[Zabbix Agent\] installed successfully
bin:zabbix\_get.exe、zabbix\_sender.exe连个文件
sbin:zabbix\_agentd.exe 客户端主进程 etc:配置文件 dev:不用理会
```![](https://bbs-img.huaweicloud.com/blogs/img/20210812/1628731194989044483.jpeg)
