社区版OceanBase部署丨【绽放吧!数据库】
snowofsummer 发表于 2021/08/10 12:15:28 2021/08/10
【摘要】 1,软件包下载https://mirrors.aliyun.com/oceanbase/community/stable/el/7/x86_64/2,部署工具安装yum install -y ob-deploy-1.0.0-1.el7.x86_64.rpmsource /etc/profile.d/obd.sh3,导入rpm文件obd mirror clone *.rpm#/root/.ob...
1,软件包下载
2,部署工具安装
3,导入rpm文件
#/root/.obd/mirror/local
obd mirror list local
[root@db02 rpm]# obd mirror list local
|                                     local Package List                                    |
| name              | version | release | arch   | md5                                      |
| libobclient       | 2.0.0   | 2.el7   | x86_64 | f73cae67e2ff5be0682ac2803aba33a7ed26430e |
| obclient          | 2.0.0   | 1.el7   | x86_64 | ae76f4a2dfaa3d4fc5a0d3db532a07351a950c50 |
| ob-deploy         | 1.0.0   | 1.el7   | x86_64 | 3cf38c88852f09d81cb0a1e8add3feaac32edb0a |
| obproxy           | 3.1.0   | 1.el7   | x86_64 | 0b17cf0459a3b53c5a2febb6572894d183154c64 |
| oceanbase-ce      | 3.1.0   | 1.el7   | x86_64 | 56f57e9843e719d830ec03c206d914f4b3adc82b |
| oceanbase-ce-libs | 3.1.0   | 1.el7   | x86_64 | b70d3839280f145a86af26811bbfcdfaeb645509 |
4,编写配置文件
mini.yaml
oceanbase-ce:
  servers:
    # Please don't use hostname, only IP can be supported
    - 127.0.0.1
  global:
    home_path: /root/observer
    # Please set devname as the network adaptor's name whose ip is  in the setting of severs.
    # if set severs as "127.0.0.1", please set devname as "lo"
    # if current ip is 192.168.1.10, and the ip's network adaptor's name is "eth0", please use "eth0"
    devname: lo
    mysql_port: 2881
    rpc_port: 2882
    zone: zone1
    cluster_id: 1
    # please set memory limit to a suitable value which is matching resource.
    memory_limit: 8G
    system_memory: 4G
    stack_size: 512K
    cpu_count: 16
    cache_wash_threshold: 1G
    __min_full_resource_pool_memory: 268435456
    workers_per_cpu_quota: 10
    schema_history_expire_time: 1d
    # The value of net_thread_count had better be same as cpu's core number.
    net_thread_count: 4
    sys_bkgd_migration_retry_num: 3
    minor_freeze_times: 10
    enable_separate_sys_clog: 0
    enable_merge_by_turn: FALSE
    datafile_disk_percentage: 20
    syslog_level: INFO
    enable_syslog_recycle: true
    max_syslog_file_count: 4
    # root_password: # root user password, can be empty
5,安装
[root@db02 rpm]# obd cluster deploy test -c /root/mini.yaml
oceanbase-ce-3.1.0 already installed
|                              Packages                             |
| Repository   | Version | Md5                                      |
| oceanbase-ce | 3.1.0   | 56f57e9843e719d830ec03c206d914f4b3adc82b |
Open ssh connection ok
Remote oceanbase-ce-3.1.0-56f57e9843e719d830ec03c206d914f4b3adc82b repository install ok
Remote oceanbase-ce-3.1.0-56f57e9843e719d830ec03c206d914f4b3adc82b repository lib check ok
127.0.0.1 initiali
6,启动并查看状态
[root@db02 rpm]# obd cluster start test
Get local repositories and plugins ok
[WARN] (127.0.0.1) open files number must not be less than 655350 (Current value: 600000)
Start observer ok
observer program health check ok
Connect to observer ok
Initialize cluster
Cluster bootstrap ok
Wait for observer init ok
|                   observer                  |
| ip        | version | port | zone  | status |
| 127.0.0.1 | 3.1.0   | 2881 | zone1 | active |
test running
[root@db02 rpm]# obd cluster display test
|                   observer                  |
7,客户端安装并连接数据库
[root@db02 rpm]# rpm -ivh libobclient-2.0.0-2.el7.x86_64.rpm
[root@db02 rpm]# rpm -ivh obclient-2.0.0-1.el7.x86_64.rpm
[root@db02 rpm]# obclient -h 127.0.0.1 -P 2881 -uroot
Welcome to the OceanBase.  Commands end with ; or \g.
Your MySQL connection id is 3221487637
Server version: 5.7.25 OceanBase 3.1.0 (r-) (Built May 30 2021 11:21:29)
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MySQL [(none)]> show databases;
| Database           |
| oceanbase          |
| information_schema |
| mysql              |
| SYS                |
| LBACSYS            |
| ORAAUDITOR         |
| test               |
7 rows in set (0.003 sec)
MySQL [(none)]> use oceanbase;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
MySQL [oceanbase]>  SELECT svr_ip,svr_port, cpu_total, mem_total, disk_total, zone FROM __all_virtual_server_stat ;
| svr_ip    | svr_port | cpu_total | mem_total  | disk_total  | zone  |
| 127.0.0.1 |     2882 |        14 | 4294967296 | 85893054464 | zone1 |
1 row in set (0.002 sec)
MySQL [oceanbase]>
【绽放吧!数据库】有奖征文火热进行中:https://bbs.huaweicloud.cn/blogs/285617
