11g grid 2节点数据安装PSU丨【绽放吧!数据库】
snowofsummer 发表于 2021/08/09 12:32:30 2021/08/09
【摘要】 1,下载OPatch版本要求 OPatch utility version 11.2.0.3.6 or later to apply this patch下载地址:6880880grid Opatch 替换:rm -rf /u01/app/11.2.0/grid/OPatch/unzip p6880880_112000_Linux-x86-64.zip -d /u01/app/11.2.0/...
集群和数据库版本:11.2.0.4.0
补丁版本:p28429134_112040_Linux-x86-64.zip    11.2.0.4.181016
OPatch版本:p6880880_112000_Linux-x86-64.zip OPatch Version: 11.2.0.3.29
1,下载OPatch
下载地址:6880880
grid Opatch 替换:
unzip p6880880_112000_Linux-x86-64.zip -d /u01/app/11.2.0/grid/
chown grid:oinstall -R /u01/app/11.2.0/grid/OPatch/
/u01/app/11.2.0/grid/OPatch/opatch version
[root@db01 soft]# /u01/app/11.2.0/grid/OPatch/opatch version
OPatch succeeded.
oracle Opatch 替换:
rm -rf /u01/app/oracle/product/11.2.0/dbhome_1/OPatch/
unzip p6880880_112000_Linux-x86-64.zip -d /u01/app/oracle/product/11.2.0/dbhome_1/
chown -R oracle:oinstall /u01/app/oracle/product/11.2.0/dbhome_1/OPatch/
/u01/app/oracle/product/11.2.0/dbhome_1/OPatch/opatch version
[root@db01 soft]# /u01/app/oracle/product/11.2.0/dbhome_1/OPatch/opatch version
2,节点01补丁安装
unzip p28429134_112040_Linux-x86-64.zip
chown -R grid:oinstall 28429134/
[root@db01 soft]# /u01/app/11.2.0/grid/OPatch/opatch auto /soft/28429134
Executing /u01/app/11.2.0/grid/perl/bin/perl /u01/app/11.2.0/grid/OPatch/crs/patch11203.pl -patchdir /soft -patchn 28429134 -paramfile /u01/app/11.2.0/grid/crs/install/crsconfig_params
This is the main log file: /u01/app/11.2.0/grid/cfgtoollogs/opatchauto2021-08-09_20-10-36.log
This file will show your detected configuration and all the steps that opatchauto attempted to do on your system:
/u01/app/11.2.0/grid/cfgtoollogs/opatchauto2021-08-09_20-10-36.report.log
2021-08-09 20:10:36: Starting Clusterware Patch Setup
Using configuration parameter file: /u01/app/11.2.0/grid/crs/install/crsconfig_params
Stopping RAC /u01/app/oracle/product/11.2.0/dbhome_1 ...
Stopped RAC /u01/app/oracle/product/11.2.0/dbhome_1 successfully
patch /soft/28429134/27735020/custom/server/27735020  apply successful for home  /u01/app/oracle/product/11.2.0/dbhome_1
patch /soft/28429134/28204707  apply successful for home  /u01/app/oracle/product/11.2.0/dbhome_1
Stopping CRS...
Stopped CRS successfully
patch /soft/28429134/27735020  apply successful for home  /u01/app/11.2.0/grid
patch /soft/28429134/28204707  apply successful for home  /u01/app/11.2.0/grid
patch /soft/28429134/28204939  apply successful for home  /u01/app/11.2.0/grid
Starting CRS...
Installing Trace File Analyzer
CRS-4123: Oracle High Availability Services has been started.
Starting RAC /u01/app/oracle/product/11.2.0/dbhome_1 ...
Started RAC /u01/app/oracle/product/11.2.0/dbhome_1 successfully
opatch auto succeeded.
3,节点02补丁安装
root解压并修改权限
补丁安装:
[root@db02 soft]# /u01/app/11.2.0/grid/OPatch/opatch auto /soft/28429134
This is the main log file: /u01/app/11.2.0/grid/cfgtoollogs/opatchauto2021-08-09_20-31-17.log
/u01/app/11.2.0/grid/cfgtoollogs/opatchauto2021-08-09_20-31-17.report.log
2021-08-09 20:31:17: Starting Clusterware Patch Setup
Stopping CRS...
Starting CRS...
4,检查补丁安装情况:
[grid@db01 ~]$ /u01/app/11.2.0/grid/OPatch/opatch lspatches
28204939;ACFS Patch Set Update : 11.2.0.4.181016 (28204939)
28204707;Database Patch Set Update : 11.2.0.4.181016 (28204707)
27735020;OCW Patch Set Update : 11.2.0.4.181016 (27735020)
[oracle@db01 ~]$ /u01/app/oracle/product/11.2.0/dbhome_1/OPatch/opatch lspatches
5,检查数据库状态
[grid@db01 ~]$ crsctl stat res -t
NAME           TARGET  STATE        SERVER                   STATE_DETAILS
Local Resources
ora.DATA.dg
               ONLINE  ONLINE       db01
               ONLINE  ONLINE       db02
ora.LISTENER.lsnr
               ONLINE  ONLINE       db01
               ONLINE  ONLINE       db02
ora.asm
               ONLINE  ONLINE       db01                     Started
               ONLINE  ONLINE       db02                     Started
ora.gsd
               OFFLINE OFFLINE      db01
               OFFLINE OFFLINE      db02
ora.net1.network
               ONLINE  ONLINE       db01
               ONLINE  ONLINE       db02
ora.ons
               ONLINE  ONLINE       db01
               ONLINE  ONLINE       db02
Cluster Resources
ora.LISTENER_SCAN1.lsnr
      1        ONLINE  ONLINE       db01
ora.cvu
ora.db01.vip
ora.db02.vip
      1        ONLINE  ONLINE       db02
ora.oc4j
ora.ora.db
      1        ONLINE  ONLINE       db01                     Open
      2        ONLINE  ONLINE       db02                     Open
ora.scan1.vip
[grid@db01 ~]$
附录:
新版本OPatch 已经不需要指定ocm response file.
Supplemental Readme - Patch Installation and Deinstallation for 12.1.0.x.x GI PSU and Database Proactive Bundle Patch (文档 ID 1591616.1)
The OPatch utility will prompt for your OCM (Oracle Configuration Manager) response file when it is run. You should enter a complete path of OCM response file if you already have created this in your environment.
If you do not have the OCM response file (ocm.rsp), then you should run the following command to create it.
As the GI home owner execute:
$ <ORACLE_HOME>/OPatch/ocm/bin/emocmrsp
Note: as latest opatch doesn't contain OCM anymore, the option "-ocmrf" is unnecessary if latest opatch is being used, refer to the following for details:
【绽放吧!数据库】有奖征文火热进行中:https://bbs.huaweicloud.cn/blogs/285617
