Flutter的两种本地存储方式之数据库(2)
坚果派 发表于 2021/08/07 07:27:14 2021/08/07
【摘要】 数据库存储如果需要持久化大量格式化后的数据,并且这些数据还会以较高的频率更新,为了考虑进一步的扩展性,通常会选用 sqlite 数据库来应对这样的场景。与文件和 SharedPreferences 相比,数据库在数据读写上可以提供更快、更灵活的解决方案。1. pubspec.yaml引入 sqflite: 1.3.2+1 path_provider: ^1.6.242.代码import...
数据库存储
1. pubspec.yaml引入
  sqflite: 1.3.2+1
2.代码
import 'package:flutter/material.dart';
import 'package:sqflite/sqflite.dart';
import 'package:path/path.dart';
import 'package:path_provider/path_provider.dart';
import 'dart:io';
void main() {
  runApp(MyApp());
class MyApp extends StatelessWidget {
  // This widget is the root of your application.
  @override
  Widget build(BuildContext context) {
    return MaterialApp(
      title: 'Flutter Demo',
      theme: ThemeData(
        primarySwatch: Colors.blue,
      home: MyHomePage(title: 'Flutter Demo Home Page'),
class MyHomePage extends StatefulWidget {
  MyHomePage({Key key, this.title}) : super(key: key);
  final String title;
  @override
  _MyHomePageState createState() => _MyHomePageState();
class Student {
  String id;
  String name;
  int score;
  //构造方法
  Student({
    this.id,
    this.name,
    this.score,
  //用于将JSON字典转换成类对象的工厂类方法
  factory Student.fromJson(Map<String, dynamic> parsedJson) {
    return Student(
      score: parsedJson['score'],
  Map<String, dynamic> toJson() {
    return {
      'id': id,
      'name': name,
      'score': score,
class _MyHomePageState extends State<MyHomePage> {
  var student1 = Student(id: '123', name: '张三', score: 110);
  query_database(id) {
    Future<Student> user = query_by_id(id);
    user.then((t) {
      print("单用户查询成功");
      print('the sroce is : ' + t.score.toString());
      student1.score = t.score;
  //插入数据
  Future<void> insertStudent(Student std) async {
    final Database db = await database;
    await db.insert(
      'students',
      std.toJson(),
      //插入冲突策略,新的替换旧的
      conflictAlgorithm: ConflictAlgorithm.replace,
  Future<Student> query_by_id(String id) async {
    List<Map> maps = await db.query('students',
        columns: ['id', 'name', 'score'], where: 'id = ?', whereArgs: [id]);
    if (maps.length > 0) {
      print("根据id查到了数据");
      return Student.fromJson(maps.first);
    print("根据id没有查到数据");
    return null;
  //初始化数据库方法
  initDB() async {
    Directory documentsDirectory = await getApplicationDocumentsDirectory();
    String path = join(documentsDirectory.path, "students_database.db");
    return await openDatabase(path, version: 1, onOpen: (db) {},
        onCreate: (Database db, int version) async {
      await db.execute('''
            CREATE TABLE students(id TEXT PRIMARY KEY, name TEXT, score INTEGER)
  Database _database;
  Future<Database> get database async {
    if (_database != null) {
      print(_database);
      return _database;
    _database = await initDB();
    print("创建新数据库");
    return _database;
  void _incrementCounter() async {
    student1.score += 1;
    await insertStudent(student1);
    setState(() {});
  Future<List<Student>> students() async {
    final List<Map<String, dynamic>> maps = await db.query('students');
    return List.generate(maps.length, (i) => Student.fromJson(maps[i]));
  @override
    return Scaffold(
      appBar: AppBar(
        title: Text(widget.title),
      body: Center(
        child: Column(
          mainAxisAlignment: MainAxisAlignment.center,
          children: <Widget>[
            Text(
              'You have pushed the button this many times:',
            Text(
              student1.score.toString(),
              style: Theme.of(context).textTheme.headline4,
      floatingActionButton: FloatingActionButton(
        onPressed: _incrementCounter,
        tooltip: 'Increment',
        child: Icon(Icons.add),
  @override
  void dispose() async {
    // TODO: implement dispose
    super.dispose();
    db.close();
评论(0
