Flutter的两种本地存储方式之 SharedPreferences(1)
坚果派 发表于 2021/08/07 07:25:39 2021/08/07
【摘要】 SharedPreferences 存储缓存少量的键值对信息(比如记录用户是否阅读了公告,或是简单的计数),可以使用 SharedPreferences。SharedPreferences 会以原生平台相关的机制,为简单的键值对数据提供持久化存储,即在 iOS 上使用 NSUserDefaults,在 Android 使用 SharedPreferences。SharedPreference...
SharedPreferences 的使用方式非常简单方便。不过需要注意的是,以键值对的方式只能存储基本类型的数据,比如 int、double、bool 和 string。
1. pubspec.yaml引入
shared_preferences: 0.5.12+4
2. 代码
import 'dart:developer';
import 'package:flutter/material.dart';
import 'package:shared_preferences/shared_preferences.dart';
void main() {
  runApp(MyApp());
class MyApp extends StatelessWidget {
  // This widget is the root of your application.
  @override
  Widget build(BuildContext context) {
    return MaterialApp(
      title: 'Flutter Demo',
      theme: ThemeData(
        primarySwatch: Colors.blue,
      home: MyHomePage(title: 'Flutter Demo Home Page'),
class MyHomePage extends StatefulWidget {
  MyHomePage({Key key, this.title}) : super(key: key);
  final String title;
  @override
  _MyHomePageState createState() => _MyHomePageState();
class _MyHomePageState extends State<MyHomePage> {
  int _counter = 0;
//涉及到耗时的文件读写,以异步的方式对这些操作进行包装
//读取SharedPreferences中key为counter的值
  Future<int> _loadCounter() async {
    SharedPreferences prefs = await SharedPreferences.getInstance();
    int counter = (prefs.getInt('counter') ?? 0);
    return counter;
//递增写入SharedPreferences中key为counter的值
  Future<void> _incrementCounter() async {
    int counter = (prefs.getInt('counter') ?? 0) + 1;
    print("当前值: " + counter.toString());
    prefs.setInt('counter', counter);  //setter(setInt)方法会同步更新内存中的键值对,然后将数据保存至磁盘,因此无需再调用更新方法强制刷新缓存
  _fresh() {
    // _incrementCounter();
    _incrementCounter().then((_) => {
          _loadCounter().then((value) {
            setState(() {
              _counter = value;
            print("before:$value");
  // void _incrementCounter() {
  //   setState(() {
  //     _counter++;
  @override
    return Scaffold(
      appBar: AppBar(
        // Here we take the value from the MyHomePage object that was created by
        // the App.build method, and use it to set our appbar title.
        title: Text(widget.title),
      body: Center(
        // Center is a layout widget. It takes a single child and positions it
        // in the middle of the parent.
        child: Column(
          mainAxisAlignment: MainAxisAlignment.center,
          children: <Widget>[
            Text(
              'You have pushed the button this many times:',
            Text(
              '$_counter',
              style: Theme.of(context).textTheme.headline4,
      floatingActionButton: FloatingActionButton(
        onPressed: _fresh,
        tooltip: 'Increment',
        child: Icon(Icons.add),
      ), // This trailing comma makes auto-formatting nicer for build methods.
评论(0
