Linux_LVM/Quota
云物互联 发表于 2021/08/06 00:09:18 2021/08/06
【摘要】 目录 目录Disk QuotaHow to enable the disk quotaPartition Disk Create LVMLVM ExtendLVM Reduce Disk Quota Characteristic: 1. For specialty user 2. Limit user and baseGroup 3....
目录
Disk Quota
Characteristic:
3. Limit of DiskSize(Volume), limit of fileCount.
step1.Edit the fstab profile and add mount parameter for disk quota with file and directory.
vim /etc/fstab
usrquota,grpquota,acl   #Addition parameter for partotion
step2. Create disk quota file in goal quota directory.
quotacheck -augcv dirName
step3. Edit disk quota
edquota -u\g user\group
setquota -u\g user\group parameters #Select parameter:soft-Volume,hard-Volume,soft-fileCount,hard-fileCount
step4. Start server
quotaon   #start
quptaoff  #stop
If the limit breakthough the soft-limit, the state will from soft-limit to hard-limit after graceTime.
setp5. Check the quota info
repquota -a
Partition Disk
Create LVM
Step1. Create PV
pvcreate deviceName
Step2. Create VG
vgcreate vgName pvName
or
vgcreate -S PESize vgName pvName   #Specify the PE size
Step3. Create LV
lvcreate -L lvSize vgName -n lvName
or
lvcreate -l PECount vgName -n lvName   #Setup the vgSize via specify PEcount
LVM Extend
vgextend vgName pvName
lvextend -L +size(M,G) lvName
resize2fs /dev/vgName/lvName
#RHEL7 使用xfs_growfs指令来刷新分区容量
LVM Reduce
umount /dev/vgName/lvName #You have to umount the LVM frist
e2fsck -f /dev/vgName/lvName
resize2fs /dev/vgName/lvName size
lvreduce -L size /dev/vgName/lvName
vgreduce vgName /dev/pvName  #The PV will be remove from VG
Get the UUID of device
blkid deviceName --> Create the UUID of device.
文章来源: is-cloud.blog.csdn.net,作者:范桂飓,版权归原作者所有,如需转载,请联系作者。
原文链接:is-cloud.blog.csdn.net/article/details/49963285
