Linux_RAID
云物互联 发表于 2021/08/06 01:09:29 2021/08/06
【摘要】 目录 目录RAID Create RAIDCheck RAIDinfo and syncScheduleRemove disk member from RAIDAdd RAID deviceStopdelete RAIDRe-add the hot spare to RAID RAID Description: Lots of disk c...
目录
RAID
Description: Lots of disk combination become a more big virtual disk by RAID, and it will have more fast I/O speed.
Create RAID
mdadm -C /dev/md[0|10|5|1] -l 10 -n[Number] -x 2 /dev/sb{a..z} -l level
 -n diskCount
 -x hotSpare
mdadm -D /dev/mdName
mdadm /dev/mdName -f /dev/sdMemberName  # Manual assign fault device
mdadm /dev/mdName -r /dev/sdMemerName   # Remove the fault device
Add RAID device
mdadm /dev/mdName -a /dev/sdMemberName
Stop/delete RAID
mdadm -D -s > /etc/mdadm.conf #create new config file -s:--scan
mdadm -S /dev/mdName --> stop/delete RAID
mdadm -As /dev/mdName -->restart RAID
mdadm -G /dev/mdName -n 6 #RAID10 not support.
文章来源: is-cloud.blog.csdn.net,作者:范桂飓,版权归原作者所有,如需转载,请联系作者。
原文链接:is-cloud.blog.csdn.net/article/details/50001191
