ROS2(Win10)更新记录21-07-27
zhangrelay 发表于 2021/07/28 00:13:46 2021/07/28
【摘要】 win10下ROS2,更新并不快,要点体会: 功能包不全节点启动速度明显比Linux慢闪退现象多 但能用……真的能用…… 详细过程如下,仅供参考 ************************************************************************ Visual Studio 2019 Developer Command Pro...
  • 功能包不全
  • 节点启动速度明显比Linux慢
  • 闪退现象多
但能用……真的能用……
详细过程如下,仅供参考
  1. **********************************************************************
  2. ** Visual Studio 2019 Developer Command Prompt v16.9.3
  3. ** Copyright (c) 2021 Microsoft Corporation
  4. **********************************************************************
  5. C:\ros_ws>choco upgrade ros-foxy-desktop -y --execution-timeout=0
  6. Chocolatey v0.10.15
  7. Upgrading the following packages:
  8. ros-foxy-desktop
  9. By upgrading you accept licenses for the packages.
  10. ros-foxy-desktop is not installed. Installing...
  11. Progress: Downloading ros-foxy-desktop 20201211.0.0.2104300001... 100%
  12. Progress: Downloading ros-foxy-desktop 20201211.0.0.2104300001... 100%
  13. vcredist2010 v10.0.40219.32503 [Approved]
  14. vcredist2010 package files upgrade completed. Performing other installation steps.
  15. Using system proxy server '127.0.0.1:60839'.
  16. Downloading vcredist2010 64 bit
  17. from 'https://download.microsoft.com/download/1/6/5/165255E7-1014-4D0A-B094-B6A430A6BFFC/vcredist_x64.exe'
  18. Using system proxy server '127.0.0.1:60839'.
  19. Progress: 100% - Completed download of C:\Users\zhangrelay\AppData\Local\Temp\chocolatey\vcredist2010\10.0.40219.32503\vcredist_x64.exe (9.8 MB).
  20. Download of vcredist_x64.exe (9.8 MB) completed.
  21. Hashes match.
  22. Installing vcredist2010...
  23. vcredist2010 has been installed.
  24. Using system proxy server '127.0.0.1:60839'.
  25. Downloading vcredist2010 32 bit
  26. from 'https://download.microsoft.com/download/1/6/5/165255E7-1014-4D0A-B094-B6A430A6BFFC/vcredist_x86.exe'
  27. Using system proxy server '127.0.0.1:60839'.
  28. Progress: 100% - Completed download of C:\Users\zhangrelay\AppData\Local\Temp\chocolatey\vcredist2010\10.0.40219.32503\vcredist_x86.exe (8.58 MB).
  29. Download of vcredist_x86.exe (8.58 MB) completed.
  30. Hashes match.
  31. Installing vcredist2010...
  32. vcredist2010 has been installed.
  33. vcredist2010 may be able to be automatically uninstalled.
  34. The upgrade of vcredist2010 was successful.
  35. Software installed as 'exe', install location is likely default.
  36. ros-foxy-desktop v20201211.0.0.2104300001
  37. ros-foxy-desktop package files upgrade completed. Performing other installation steps.
  38. Installing ros-foxy-desktop...
  39. ros-foxy-desktop has been installed.
  40. ros-foxy-desktop can be automatically uninstalled.
  41. The upgrade of ros-foxy-desktop was successful.
  42. Software installed to 'c:\opt\ros\foxy\x64\'
  43. Chocolatey upgraded 2/2 packages.
  44. See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
  45. C:\ros_ws>choco upgrade ros-foxy-desktop -y --execution-timeout=0
  46. Chocolatey v0.10.15
  47. Upgrading the following packages:
  48. ros-foxy-desktop
  49. By upgrading you accept licenses for the packages.
  50. ros-foxy-desktop v20201211.0.0.2104300001 is the latest version available based on your source(s).
  51. Chocolatey upgraded 0/1 packages.
  52. See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
  53. C:\ros_ws>rviz2
  54. [INFO] [1627340879.662842000] [rviz2]: Stereo is NOT SUPPORTED
  55. [INFO] [1627340879.663882400] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
  56. [INFO] [1627340879.718344200] [rviz2]: Stereo is NOT SUPPORTED
  57. C:\ros_ws>rqt
  58. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  59. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  60. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  61. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  62. RosPluginProvider.load(rqt_graph/RosGraph) exception raised in __builtin__.__import__(rqt_graph.ros_graph, [RosGraph]):
  63. Traceback (most recent call last):
  64. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  65. module = __builtin__.__import__(
  66. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_graph\ros_graph.py", line 43, in <module>
  67. from qt_dotgraph.dot_to_qt import DotToQtGenerator
  68. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_dotgraph\dot_to_qt.py", line 35, in <module>
  69. import pydot
  70. ModuleNotFoundError: No module named 'pydot'
  71. PluginManager._load_plugin() could not load plugin "rqt_graph/RosGraph":
  72. Traceback (most recent call last):
  73. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler.py", line 102, in load
  74. self._load()
  75. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler_direct.py", line 55, in _load
  76. self._plugin = self._plugin_provider.load(self._instance_id.plugin_id, self._context)
  77. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  78. instance = plugin_provider.load(plugin_id, plugin_context)
  79. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  80. instance = plugin_provider.load(plugin_id, plugin_context)
  81. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui_py\ros_py_plugin_provider.py", line 64, in load
  82. return super(RosPyPluginProvider, self).load(plugin_id, ros_plugin_context)
  83. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  84. instance = plugin_provider.load(plugin_id, plugin_context)
  85. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 91, in load
  86. raise e
  87. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  88. module = __builtin__.__import__(
  89. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_graph\ros_graph.py", line 43, in <module>
  90. from qt_dotgraph.dot_to_qt import DotToQtGenerator
  91. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_dotgraph\dot_to_qt.py", line 35, in <module>
  92. import pydot
  93. ModuleNotFoundError: No module named 'pydot'
  94. C:\ros_ws>pip3 install pydot
  95. Collecting pydot
  96. Downloading pydot-1.4.2-py2.py3-none-any.whl (21 kB)
  97. Requirement already satisfied: pyparsing>=2.1.4 in c:\opt\ros\foxy\x64\lib\site-packages (from pydot) (2.4.7)
  98. Installing collected packages: pydot
  99. Successfully installed pydot-1.4.2
  100. WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
  101. You should consider upgrading via the 'c:\opt\ros\foxy\x64\python.exe -m pip install --upgrade pip' command.
  102. C:\ros_ws>rqt
  103. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  104. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  105. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  106. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  107. C:\ros_ws>rqt
  108. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  109. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  110. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  111. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  112. RosPluginProvider.load(rqt_top/TOP) exception raised in __builtin__.__import__(rqt_top.top_plugin, [Top]):
  113. Traceback (most recent call last):
  114. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  115. module = __builtin__.__import__(
  116. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\top_plugin.py", line 38, in <module>
  117. from rqt_top.node_info import NodeInfo
  118. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\node_info.py", line 28, in <module>
  119. import psutil
  120. ModuleNotFoundError: No module named 'psutil'
  121. PluginManager._load_plugin() could not load plugin "rqt_top/TOP":
  122. Traceback (most recent call last):
  123. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler.py", line 102, in load
  124. self._load()
  125. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler_direct.py", line 55, in _load
  126. self._plugin = self._plugin_provider.load(self._instance_id.plugin_id, self._context)
  127. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  128. instance = plugin_provider.load(plugin_id, plugin_context)
  129. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  130. instance = plugin_provider.load(plugin_id, plugin_context)
  131. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui_py\ros_py_plugin_provider.py", line 64, in load
  132. return super(RosPyPluginProvider, self).load(plugin_id, ros_plugin_context)
  133. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  134. instance = plugin_provider.load(plugin_id, plugin_context)
  135. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 91, in load
  136. raise e
  137. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  138. module = __builtin__.__import__(
  139. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\top_plugin.py", line 38, in <module>
  140. from rqt_top.node_info import NodeInfo
  141. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\node_info.py", line 28, in <module>
  142. import psutil
  143. ModuleNotFoundError: No module named 'psutil'
  144. RosPluginProvider.load(rqt_top/TOP) exception raised in __builtin__.__import__(rqt_top.top_plugin, [Top]):
  145. Traceback (most recent call last):
  146. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  147. module = __builtin__.__import__(
  148. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\top_plugin.py", line 38, in <module>
  149. from rqt_top.node_info import NodeInfo
  150. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\node_info.py", line 28, in <module>
  151. import psutil
  152. ModuleNotFoundError: No module named 'psutil'
  153. PluginManager._load_plugin() could not load plugin "rqt_top/TOP":
  154. Traceback (most recent call last):
  155. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler.py", line 102, in load
  156. self._load()
  157. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler_direct.py", line 55, in _load
  158. self._plugin = self._plugin_provider.load(self._instance_id.plugin_id, self._context)
  159. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  160. instance = plugin_provider.load(plugin_id, plugin_context)
  161. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  162. instance = plugin_provider.load(plugin_id, plugin_context)
  163. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui_py\ros_py_plugin_provider.py", line 64, in load
  164. return super(RosPyPluginProvider, self).load(plugin_id, ros_plugin_context)
  165. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  166. instance = plugin_provider.load(plugin_id, plugin_context)
  167. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 91, in load
  168. raise e
  169. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  170. module = __builtin__.__import__(
  171. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\top_plugin.py", line 38, in <module>
  172. from rqt_top.node_info import NodeInfo
  173. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_top\node_info.py", line 28, in <module>
  174. import psutil
  175. ModuleNotFoundError: No module named 'psutil'
  176. C:\ros_ws>pip3 install psutil
  177. Collecting psutil
  178. Downloading psutil-5.8.0-cp38-cp38-win_amd64.whl (245 kB)
  179. |████████████████████████████████| 245 kB 595 kB/s
  180. Installing collected packages: psutil
  181. Successfully installed psutil-5.8.0
  182. WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
  183. You should consider upgrading via the 'c:\opt\ros\foxy\x64\python.exe -m pip install --upgrade pip' command.
  184. C:\ros_ws>rqt
  185. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  186. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  187. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  188. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  189. RosPluginProvider.load(rqt_publisher/Publisher) exception raised in __builtin__.__import__(rqt_publisher.publisher, [Publisher]):
  190. Traceback (most recent call last):
  191. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  192. module = __builtin__.__import__(
  193. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_publisher\publisher.py", line 60, in <module>
  194. numpy.float16, numpy.float32, numpy.float64, numpy.float128,
  195. File "c:\opt\ros\foxy\x64\lib\site-packages\numpy\__init__.py", line 214, in __getattr__
  196. raise AttributeError("module {!r} has no attribute "
  197. AttributeError: module 'numpy' has no attribute 'float128'
  198. PluginManager._load_plugin() could not load plugin "rqt_publisher/Publisher":
  199. Traceback (most recent call last):
  200. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler.py", line 102, in load
  201. self._load()
  202. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler_direct.py", line 55, in _load
  203. self._plugin = self._plugin_provider.load(self._instance_id.plugin_id, self._context)
  204. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  205. instance = plugin_provider.load(plugin_id, plugin_context)
  206. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  207. instance = plugin_provider.load(plugin_id, plugin_context)
  208. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui_py\ros_py_plugin_provider.py", line 64, in load
  209. return super(RosPyPluginProvider, self).load(plugin_id, ros_plugin_context)
  210. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  211. instance = plugin_provider.load(plugin_id, plugin_context)
  212. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 91, in load
  213. raise e
  214. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 80, in load
  215. module = __builtin__.__import__(
  216. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_publisher\publisher.py", line 60, in <module>
  217. numpy.float16, numpy.float32, numpy.float64, numpy.float128,
  218. File "c:\opt\ros\foxy\x64\lib\site-packages\numpy\__init__.py", line 214, in __getattr__
  219. raise AttributeError("module {!r} has no attribute "
  220. AttributeError: module 'numpy' has no attribute 'float128'
  221. PluginManager._load_plugin() could not load plugin "rqt_plot/Plot":
  222. Traceback (most recent call last):
  223. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler.py", line 102, in load
  224. self._load()
  225. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\plugin_handler_direct.py", line 55, in _load
  226. self._plugin = self._plugin_provider.load(self._instance_id.plugin_id, self._context)
  227. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  228. instance = plugin_provider.load(plugin_id, plugin_context)
  229. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  230. instance = plugin_provider.load(plugin_id, plugin_context)
  231. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui_py\ros_py_plugin_provider.py", line 64, in load
  232. return super(RosPyPluginProvider, self).load(plugin_id, ros_plugin_context)
  233. File "c:\opt\ros\foxy\x64\lib\site-packages\qt_gui\composite_plugin_provider.py", line 72, in load
  234. instance = plugin_provider.load(plugin_id, plugin_context)
  235. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_gui\ros_plugin_provider.py", line 107, in load
  236. return class_ref(plugin_context)
  237. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_plot\plot.py", line 57, in __init__
  238. self._data_plot = DataPlot(self._widget)
  239. File "c:\opt\ros\foxy\x64\lib\site-packages\rqt_plot\data_plot\__init__.py", line 159, in __init__
  240. raise RuntimeError(
  241. RuntimeError: No usable plot type found. Install at least one of: PyQtGraph, MatPlotLib (at least 1.4.0) or Python-Qwt5.
  242. C:\ros_ws>pip3 install numpy
  243. Requirement already satisfied: numpy in c:\opt\ros\foxy\x64\lib\site-packages (1.19.2)
  244. WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
  245. You should consider upgrading via the 'c:\opt\ros\foxy\x64\python.exe -m pip install --upgrade pip' command.
  246. C:\ros_ws>pip3 install PyQtGraph
  247. Collecting PyQtGraph
  248. Downloading pyqtgraph-0.12.2-py3-none-any.whl (959 kB)
  249. |████████████████████████████████| 959 kB 435 kB/s
  250. Requirement already satisfied: numpy>=1.17.0 in c:\opt\ros\foxy\x64\lib\site-packages (from PyQtGraph) (1.19.2)
  251. Installing collected packages: PyQtGraph
  252. Successfully installed PyQtGraph-0.12.2
  253. WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
  254. You should consider upgrading via the 'c:\opt\ros\foxy\x64\python.exe -m pip install --upgrade pip' command.
  255. C:\ros_ws>pip3 install MatPlotLib
  256. Collecting MatPlotLib
  257. Downloading matplotlib-3.4.2-cp38-cp38-win_amd64.whl (7.1 MB)
  258. |████████████████████████████████| 7.1 MB 1.1 MB/s
  259. Requirement already satisfied: python-dateutil>=2.7 in c:\opt\ros\foxy\x64\lib\site-packages (from MatPlotLib) (2.8.1)
  260. Collecting cycler>=0.10
  261. Using cached cycler-0.10.0-py2.py3-none-any.whl (6.5 kB)
  262. Requirement already satisfied: pyparsing>=2.2.1 in c:\opt\ros\foxy\x64\lib\site-packages (from MatPlotLib) (2.4.7)
  263. Collecting pillow>=6.2.0
  264. Downloading Pillow-8.3.1-1-cp38-cp38-win_amd64.whl (3.2 MB)
  265. |████████████████████████████████| 3.2 MB 726 kB/s
  266. Collecting kiwisolver>=1.0.1
  267. Downloading kiwisolver-1.3.1-cp38-cp38-win_amd64.whl (51 kB)
  268. |████████████████████████████████| 51 kB 990 kB/s
  269. Requirement already satisfied: numpy>=1.16 in c:\opt\ros\foxy\x64\lib\site-packages (from MatPlotLib) (1.19.2)
  270. Requirement already satisfied: six>=1.5 in c:\opt\ros\foxy\x64\lib\site-packages (from python-dateutil>=2.7->MatPlotLib) (1.15.0)
  271. Installing collected packages: cycler, pillow, kiwisolver, MatPlotLib
  272. Successfully installed MatPlotLib-3.4.2 cycler-0.10.0 kiwisolver-1.3.1 pillow-8.3.1
  273. WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
  274. You should consider upgrading via the 'c:\opt\ros\foxy\x64\python.exe -m pip install --upgrade pip' command.
  275. C:\ros_ws>pip3 install Python-Qwt5
  276. ERROR: Could not find a version that satisfies the requirement Python-Qwt5 (from versions: none)
  277. ERROR: No matching distribution found for Python-Qwt5
  278. WARNING: You are using pip version 20.2.3; however, version 21.2.1 is available.
  279. You should consider upgrading via the 'c:\opt\ros\foxy\x64\python.exe -m pip install --upgrade pip' command.
  280. C:\ros_ws>rqt
  281. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  282. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_gui_cpp/plugin.xml" in package "rqt_gui_cpp" not found
  283. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  284. RosPluginProvider._parse_plugin_xml() plugin file "c:\opt\ros\foxy\x64\share\rqt_image_view/plugin.xml" in package "rqt_image_view" not found
  285. C:\ros_ws>choco upgrade ros-foxy-rqt
  286. Chocolatey v0.10.15
  287. Upgrading the following packages:
  288. ros-foxy-rqt
  289. By upgrading you accept licenses for the packages.
  290. ros-foxy-rqt is not installed. Installing...
  291. ros-foxy-rqt not installed. The package was not found with the source(s) listed.
  292. Source(s): 'https://aka.ms/ros/public;https://chocolatey.org/api/v2/'
  293. NOTE: When you specify explicit sources, it overrides default sources.
  294. If the package version is a prerelease and you didn't specify `--pre`,
  295. the package may not be found.
  296. Please see https://chocolatey.org/docs/troubleshooting for more
  297. assistance.
  298. Chocolatey upgraded 0/1 packages. 1 packages failed.
  299. See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
  300. Failures
  301. - ros-foxy-rqt - ros-foxy-rqt not installed. The package was not found with the source(s) listed.
  302. Source(s): 'https://aka.ms/ros/public;https://chocolatey.org/api/v2/'
  303. NOTE: When you specify explicit sources, it overrides default sources.
  304. If the package version is a prerelease and you didn't specify `--pre`,
  305. the package may not be found.
  306. Please see https://chocolatey.org/docs/troubleshooting for more
  307. assistance.
  308. C:\ros_ws>choco upgrade ros-foxy-rqt-tf-tree
  309. Chocolatey v0.10.15
  310. Upgrading the following packages:
  311. ros-foxy-rqt-tf-tree
  312. By upgrading you accept licenses for the packages.
  313. ros-foxy-rqt-tf-tree is not installed. Installing...
  314. ros-foxy-rqt-tf-tree not installed. The package was not found with the source(s) listed.
  315. Source(s): 'https://aka.ms/ros/public;https://chocolatey.org/api/v2/'
  316. NOTE: When you specify explicit sources, it overrides default sources.
  317. If the package version is a prerelease and you didn't specify `--pre`,
  318. the package may not be found.
  319. Please see https://chocolatey.org/docs/troubleshooting for more
  320. assistance.
  321. Chocolatey upgraded 0/1 packages. 1 packages failed.
  322. See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
  323. Failures
  324. - ros-foxy-rqt-tf-tree - ros-foxy-rqt-tf-tree not installed. The package was not found with the source(s) listed.
  325. Source(s): 'https://aka.ms/ros/public;https://chocolatey.org/api/v2/'
  326. NOTE: When you specify explicit sources, it overrides default sources.
  327. If the package version is a prerelease and you didn't specify `--pre`,
  328. the package may not be found.
  329. Please see https://chocolatey.org/docs/troubleshooting for more
  330. assistance.
  331. C:\ros_ws>
原文链接:zhangrelay.blog.csdn.net/article/details/119133480
