LeetCode之Add Two Numbers
chenyu 发表于 2021/07/27 01:56:25 2021/07/27
【摘要】 LeetCode之Add Two Numbers 题目:You are given two linked lists representing two non-negative numbers. The digits are stored in reverse order and each of their nodes contain a single digit. ...
题目:You are given two linked lists representing two non-negative numbers. The digits are stored in reverse order and each of their nodes contain a single digit. Add the two numbers and return it as a linked list.
Input: (2 -> 4 -> 3) + (5 -> 6 -> 4)
Output: 7 -> 0 -> 8
Subscribe to see which companies asked this question
中文翻译:
给你两个表示两个非负数字的链表。数字以相反的顺序存储,其节点包含单个数字。将这两个数字相加并将其作为一个链表返回。
输入: (2 -> 4 -> 3) + (5 -> 6 -> 4)输出: 7 -> 0 -> 8
java实现:
  1. /**
  2. * Definition for singly-linked list.
  3. * public class ListNode {
  4. * int val;
  5. * ListNode next;
  6. * ListNode(int x) { val = x; }
  7. * }
  8. */
  9. public class Solution {
  10. public ListNode
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/49593549
