Android之万能适配器Adapter的使用
chenyu 发表于 2021/07/27 01:50:04 2021/07/27
【摘要】 万能适配器   万能适配器共有两个部分:SuperViewHolder 和 SuperBaseAdapter   万能的ViewHolder public class SuperViewHolder { private SparseArray<View> mViews; private View mConve...
万能适配器
万能的ViewHolder
  1. public class SuperViewHolder {
  2. private SparseArray<View> mViews;
  3. private View mConvertView;
  4. private int mPosition;
  5. public SuperViewHolder(Context context, ViewGroup parent, int layoutId, int position) {
  6. mPosition = position;
  7. mViews = new SparseArray<>();
  8. mConvertView = LayoutInflater.from(context).inflate(layoutId, parent, false);
  9. mConvertView.setTag(this);
  10. }
  11. public static SuperViewHolder make(Context context, int layoutId, View convertView, ViewGroup parent, int position) {
  12. if (convertView == null) {
  13. return new SuperViewHolder(context, parent, layoutId, position);
  14. } else {
  15. SuperViewHolder superVie
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/48757635
