Android之mediarecorder中的方法以及工作流程的过程
chenyu 发表于 2021/07/27 01:37:52 2021/07/27
【摘要】 嵌套、关联的类   class MediaRecorder.AudioEncoder 定义音频编码 class MediaRecorder.AudioSource 定义声音资源 interface MediaRecorder.OnErrorListener Interface definition for a callbac...
嵌套、关联的类
class
定义音频编码
class
定义声音资源
interface
Interface definition for a callback to be invoked when an error occurs while recording.
interface
MediaRecorder.OnInfoListener
class
MediaRecorder.OutputFormat
定义输出格式
class
MediaRecorder.VideoEncoder
定义视频编码
class
MediaRecorder.VideoSource
定义视频source
3 主要方法:
final static int
getAudioSourceMax()
Gets the maximum value for audio sources.
获取音频信号源的最高值。
int
getMaxAmplitude()
Returns the maximum absolute amplitude that was sampled since the last call to this method.
最后调用这个方法采样的时候返回最大振幅的绝对值
void
prepare()
Prepares the recorder to begin capturing and encoding data.
准备recorder 开始捕获和编码数据
void
release()
Releases resources associated with this MediaRecorder object.
发布与此MediaRecorder对象关联的资源
void
reset()
Restarts the MediaRecorder to its idle state.
重新启动mediarecorder到空闲状态
void
setAudioChannels(int numChannels)
Sets the number of audio channels for recording.
设置录制的音频通道数。
void
setAudioEncoder(int audio_encoder)
Sets the audio encoder to be used for recording.
设置audio的编码格式
void
setAudioEncodingBitRate(int bitRate)
Sets the audio encoding bit rate for recording.
设置录制的音频编码比特率
void
setAudioSamplingRate(int samplingRate)
Sets the audio sampling rate for recording.
设置录制的音频采样率。
void
setAudioSource(int audio_source)
Sets the audio source to be used for recording.
设置用于录制的音源。
void
setAuxiliaryOutputFile(String path)
Pass in the file path for the auxiliary time lapse video.
辅助时间的推移视频文件的路径传递。
void
setAuxiliaryOutputFile(FileDescriptor fd)
Pass in the file descriptor for the auxiliary time lapse video.
在文件描述符传递的辅助时间的推移视频
void
setCamera(Camera c)
Sets a Camera to use for recording.
设置一个recording的摄像头
void
setCaptureRate(double fps)
Set video frame capture rate.
设置视频帧的捕获率
void
setMaxDuration(int max_duration_ms)
Sets the maximum duration (in ms) of the recording session.
设置记录会话的最大持续时间(毫秒)
void
setMaxFileSize(long max_filesize_bytes)
Sets the maximum filesize (in bytes) of the recording session.
设置记录会话的最大大小(以字节为单位)
void
setOnErrorListener(MediaRecorder.OnErrorListener l)
Register a callback to be invoked when an error occurs while recording.
注册一个回调被调用发生错误时,同时录制
void
setOnInfoListener(MediaRecorder.OnInfoListener listener)
Register a callback to be invoked when an informational event occurs while recording.
注册要同时记录一个信息事件发生时调用的回调。
void
setOrientationHint(int degrees)
Sets the orientation hint for output video playback.
设置输出的视频播放的方向提示
void
setOutputFile(FileDescriptor fd)
Pass in the file descriptor of the file to be written.
传递要写入的文件的文件描述符
void
setOutputFile(String path)
Sets the path of the output file to be produced.
设置输出文件的路径
void
setOutputFormat(int output_format)
Sets the format of the output file produced during recording.
设置在录制过程中产生的输出文件的格式
void
setPreviewDisplay(Surface sv)
Sets a Surface to show a preview of recorded media (video).
表面设置显示记录媒体(视频)的预览
void
setProfile(CamcorderProfile profile)
Uses the settings from a CamcorderProfile object for recording.
从一个记录CamcorderProfile对象的使用设置
void
setVideoEncoder(int video_encoder)
Sets the video encoder to be used for recording.
设置视频编码器,用于录制
void
setVideoEncodingBitRate(int bitRate)
Sets the video encoding bit rate for recording.
设置录制的视频编码比特率。
void
setVideoFrameRate(int rate)
Sets the frame rate of the video to be captured.
设置要捕获的视频帧速率
void
setVideoSize(int width, int height)
Sets the width and height of the video to be captured.
设置要捕获的视频的宽度和高度
void
setVideoSource(int video_source)
Sets the video source to be used for recording.
开始捕捉和编码数据到setOutputFile(指定的文件)
void
start()
Begins capturing and encoding data to the file specified with setOutputFile().
void
stop()
Stops recording.
停止recording
视频编码格式:default,H263,H264,MPEG_4_SP
获得视频资源:default,CAMERA
音频编码格式:default,AAC,AMR_NB,AMR_WB,
获得音频资源:defalut,camcorder,mic,voice_call,voice_communication,voice_downlink, voice_recognition,  voice_uplink;
输出方式:amr_nb,amr_wb,default,mpeg_4,raw_amr,three_gpp.
4 流程分析
一、 java层
media recorder state machine:
1、java应用层
java应用层主要是一些接口的调用,它并没有具体功能代码的实现,java应用层的代码路径为:
android/packages/apps/SoundRecorder/src/com/android/soundrecorder/
该目录下有文件: SoundRecorder.java Recorder.java VUMeter.java
soundrecorder.java是程序的入口文件,我们在可以在里面设置文件输出编码格式的格式,现在系统默认支持两种格式amr和3gpp格式。设置代码如下:
mRequestedType =AUDIO_3GPP; //02 AUDIO_AMR;
接着运行mRecorder = new Recorder();创建一个Recorder类。Recorder类在Recorder.java中定义。
Recorder的startRecording方法启动了java层的录音。startRecording方法中首先创建一个Mediarecorder的类,然后调用Mediarecorder的方法完成设置audio源、设置输出文件格式、audio编码格式、设置输出文件,然后检查MediaRecorder是否准备好了。如果准备好就启动。如果没有准备好就抛出异常然后重新设置MediaRecorder和释放MediaRecorder。代码如下所示:
mRecorder = new MediaRecorder();
mRecorder.setAudioSource(MediaRecorder.AudioSource.MIC);
mRecorder.setOutputFormat(outputfileformat);
mRecorder.setAudioEncoder(MediaRecorder.AudioEncoder.AMR_NB);
mRecorder.setOutputFile(mSampleFile.getAbsolutePath());
// Handle IOException
try {
mRecorder.prepare();
} catch(IOException exception) {
setError(INTERNAL_ERROR);
mRecorder.reset();
mRecorder.release();
mRecorder = null;
return;
mRecorder.start();
2、JAVA Framework层
Java的framework层代码位于:
frameworks/base/media/java/android/media/MediaRecorder.java
它没有具体的实现只是一个接口而已。
3、JAVA本地调用部分(JNI):
frameworks/base/media/jni/android_media_MediaRecorder.cpp
jni层的只是实现了方法的注册,为java层调用C++程序提供一种注册。
这三给部分的程序会编译成一个libmedia_jni.so库,java层序的调用都是调用该库中的接口。具体的实现要要在我们的多媒体底层库。
二、 多媒体底层库
1、ImediaRecorder.cpp
Imediarecorder.cpp文件中实现了BP功能。BP和BN是通过binder来通信的。Bp主要是用来处理java层传下来的服务请求。然后通过transact将处理请求传给bn(通过binder)。其接口如下所示:
class BpMediaRecorder: public BpInterface
BpMediaRecorder(const sp& impl) : BpInterface(impl) {}
status_t setCamera(const sp& camera);
status_t setPreviewSurface(const sp& surface);
status_t init();
status_t setVideoSource(int vs);
status_t setAudioSource(int as);
status_t setOutputFormat(int of);
status_t setAudioEncoder(int ae);
status_t setOutputFile(const char* path);
status_t prepare();
status_t getMaxAmplitude(int* max);
上面的每个函数中都用transact方法来向bn发出请求。然后调用return reply.readInt32();将从bn返回的数据传送个他们的调用函数。
2、Mediarecorder.cpp
Bn的实现是在Mediarecorder.cpp文件中。BN是用来处理bp的请求,当bn将数将处理完后将数据通过transact传给回bp(通过binder)。MediaRecorder.cpp文件的实现方法与ImediaRecorder,cpp对应,主要是用来接收ImediaRecorder发送过来的请求。
MediaRecorder::MediaRecorder()
{ LOGV("constructor");
sp sm = defaultServiceManager();
sp binder;
do {
binder =sm->getService(String16("media.player"));
if (binder != NULL) {
break;
usleep(500000); // 0.5 s
} while(true);
sp service = interface_cast(binder);
if (service != NULL) {
mMediaRecorder = service->createMediaRecorder(getpid());
if (mMediaRecorder != NULL) {
mCurrentState = MEDIA_RECORDER_IDLE;
doCleanUp();
该文件操作的方法是mMediaRecorder的方法,它主要是同过binder机制将请求传输送给mediarecorder的服务进程。
3、多媒体服务部分
mediaRecorder的服务文件是MediaRecorderClient.cpp,它主要调用的是PVMediaRecorder的实现方法,在此请求opencore的服务。
MediaRecorderClient::MediaRecorderClient(pid_t pid)
LOGV("Client constructor");
mPid = pid;
mRecorder = new PVMediaRecorder();
三、Opencore
我们先从pvmediarecorder.cpp文件分析。
在PVMediaRecorder中首先创建一个AuthorDriverWrapper的对象。PVMediaRecorder将它的方法通过author_command包装。然后通过AuthorDriverWrapper的enqueueCommand将命令发送请求队列中。
PVMediaRecorder的setOutputFile方法会打开我们上面指定的文件路径下的文件,为写文件作好准备。代码如下:
int fd = open(path, O_RDWR | O_CREAT );
接着分析authordriver.cpp文件
AuthorDriverWrapper::AuthorDriverWrapper()
mAuthorDriver = new AuthorDriver();
我们在AuthorDriverWrapper首先创建一个AuthorDriver的对象.。我们来看AuthorDriverWrapper的enqueueCommand方法,可以看到,我们在pvmediarecorder中调用的enqueuecommand实际上调用的是authordriver的enqueuecommand方法。
status_t AuthorDriverWrapper::enqueueCommand(author_command*ac, media_completion_f comp, void *cookie)
{ if (mAuthorDriver) {
return mAuthorDriver->enqueueCommand(ac, comp, cookie);
return NO_INIT;
四、audioflinger层和audiorecord
1、AudioRecord
音频系统的对外接口是AudioRecord,它通过iBinder来远程调用Audioflinger的openRecorder函数。AudioRecord构造函数如下:
1:AudioRecord
AudioRecord::AudioRecord(
int streamType,
uint32_t sampleRate,
int format,
int channelCount,
int frameCount,
uint32_t flags,
callback_t cbf,
void* user,
int notificationFrames)
: mStatus(NO_INIT)
log_wj("ENTERIN::--%s---%s---\n",__FILE__,__FUNCTION__);
mStatus = set(streamType, sampleRate, format, channelCount,
frameCount, flags, cbf, user, notificationFrames);
调用:
status_t AudioRecord::set(int streamType,
int format,
int channelCount,
int frameCount,
uint32_t flags,
callback_t cbf,
void* user,
int notificationFrames,
bool threadCanCallJava)
const sp& audioFlinger = AudioSystem::get_audio_flinger();
//获取缓存大小,间接调用我们修改过该函数(经过三次调用中转),返回值为//channelCount*320
AudioSystem::getInputBufferSize(sampleRate, format,channelCount, &inputBuffSizeInBytes);
//远程调用audioFlinger的openrecord函数,openRecord相当于audioflinger为audioRecord
//开辟相应的服务窗口
sp record = audioFlinger->openRecord(getpid(),streamType,
sampleRate, format,
channelCount,
frameCount,
((uint16_t)flags) << 16,
&status);
//创建一个线程用来处理
mClientRecordThread = new ClientRecordThread(*this,threadCanCallJava);
AudioRecord相当于一个代理,它的线程是用来处理其它客户的请求。
2、AudioFlinger
sp AudioFlinger::openRecord(
pid_t pid,
int streamType,
int format,
int channelCount,
int frameCount,
uint32_t flags,
status_t *status)
// AudioRecord线程
if (mAudioRecordThread == 0) {
LOGE("Audio record thread not started");
lStatus = NO_INIT;
goto Exit;
// add client to list
{ // scope for mLock
Mutex::Autolock _l(mLock);
wclient = mClients.valueFor(pid);
if (wclient != NULL) {
client = wclient.promote();
client = new Client(this, pid);
mClients.add(pid, client);
// create new record track. The record track uses one trackin mHardwareMixerThread by //convention.
//生成一个recordTrack用来作为数据的中转(audioflinger与audiorecord之间)。
//他们使用audio_track_cblk_t数据结构来传输数据。
recordTrack = new MixerThread::RecordTrack(mHardwareMixerThread,client, streamType, sampleRate, format, channelCount, frameCount, flags);
if (recordTrack->getCblk() == NULL) {
recordTrack.clear();
lStatus = NO_MEMORY;
goto Exit;
// return to handle to client------我们的audiorecord。
recordHandle = new RecordHandle(recordTrack);
AudioRecord和AudioFlinger操作的都是RecordTrack实例,AudioRecord通过它的执行控制操作(start/stop)和读取操作(read)。Audiorecord的start/stop操作可以理解为一个开关,控制的是AudiorecordThread的运行与否。
Audioflinger则负责从音频设备读取数据放置到audio_track_cblk_t数据结构中。
Audioflinger对数据的读取在AudioFlinger::AudioRecordThread::threadLoop()函数中。在第一次启动的时候会打开一个AudioStreamIn的对象,并设置参数。
input =mAudioHardware->openInputStream(mRecordTrack->format(),
mRecordTrack->channelCount(),mRecordTrack->sampleRate(),
&mStartStatus,
(AudioSystem::audio_in_acoustics)(mRecordTrack->mFlags>> 16));
读取数据的代码如下:
if (LIKELY(mRecordTrack->getNextBuffer(&buffer) ==NO_ERROR&&
(int)buffer.frameCount == inFrameCount) ) {
ssize_t bytesRead = input->read(buffer.raw,inBufferSize);
mRecordTrack->releaseBuffer(&buffer);
mRecordTrack->overflow();
首先从audio_track_cblk_t取得缓冲区,然后调用input的read方法读取数据,最后释放缓冲区,检查是否溢出。
五、 硬件抽象层
硬件抽象层主要实现了AudioStreamInALSA和AudioStreamOutALSA两个类,这两个类又会调用该文件下的ALSAStreamOps类的方法。AudioStreamInALSA是录音部分调用的路径。在AudioStreamInALSA的构造函数中会对alsa进行一些初始化参数设置。AudioStreamInALSA的read方法是最主要的方法,audioflinger层的read调用就是对AudioStreamInALSA的read的调用。由于录音部分出现单声道和双声道数据传输的问题,修改read方法如下,即可实现了录音功能正常,避免了在编码的时候修改数据时其他编码仍不能工作的弊端。
ssize_t AudioStreamInALSA::read(void *buffer, ssize_tbytes)
{ snd_pcm_sframes_t n;
status_t err;
short int *tmp1,*tmp2;
int i;
AutoMutex lock(mLock);
tmp1=(short int *)malloc(bytes*2);
n = snd_pcm_readi(mHandle, tmp1,snd_pcm_bytes_to_frames(mHandle, bytes*2));
if (n < 0 && mHandle) {
n = snd_pcm_recover(mHandle, n, 0);
tmp2=(short int *)buffer;
for(i=0;i
tmp2[i]=tmp1[2*i];
free(tmp1);
return static_cast(n/2);
snd_pcm_readi调用的是alsa库函数,跟踪执行最终会调用alsa库下的snd_pcm_hw_readi函数。snd_pcm_hw_readi会调用err = ioctl(fd,SNDRV_PCM_IOCTL_READI_FRAMES, &xferi);最终与kernel相联系。
5主要能设置列举
1 setAudioChannels(int numChannels) 设置录制的音频通道数。
2 setAudioEncoder(int audio_encoder) 设置audio的编码格式
3 setAudioEncodingBitRate(int bitRate)  设置录制的音频编码比特率
4 setAudioSamplingRate(int samplingRate) 设置录制的音频采样率。
5 setAudioSource(int audio_source) 设置用于录制的音源。
6 setAuxiliaryOutputFile(String path)  辅助时间的推移视频文件的路径传递。
7 setAuxiliaryOutputFile(FileDescriptor fd)在文件描述符传递的辅助时间的推移视频
8 setCamera(Camera c) 设置一个recording的摄像头
9 setCaptureRate(double fps) 设置视频帧的捕获率
10 setMaxDuration(int max_duration_ms) 设置记录会话的最大持续时间(毫秒)
11 setMaxFileSize(long max_filesize_bytes) 设置记录会话的最大大小(以字节为单位)
12 setOutputFile(FileDescriptor fd) 传递要写入的文件的文件描述符
13 setOutputFile(String path)  设置输出文件的路径
14 setOutputFormat(int output_format) 设置在录制过程中产生的输出文件的格式
15 setPreviewDisplay(Surface sv) 表面设置显示记录媒体(视频)的预览
16 setVideoEncoder(int video_encoder) 设置视频编码器,用于录制
17 setVideoEncodingBitRate(int bitRate) 设置录制的视频编码比特率。
18 setVideoFrameRate(int rate) 设置要捕获的视频帧速率
19 setVideoSize(int width, int height) 设置要捕获的视频的宽度和高度
20 setVideoSource(int video_source)  开始捕捉和编码数据到setOutputFile(指定的文件)
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/52027354
