Android之使用AIDL时的跨进程回调—Server回调Client
chenyu 发表于 2021/07/27 00:25:34 2021/07/27
【摘要】 首先建立在server端建立两个aidl文件 ITaskCallback.aidl 用于存放要回调client端的方法 package com.cmcc.demo.server; interface ITaskCallback { void actionPerformed(int actionId); } ITaskBinder.aidl...
  1. package com.cmcc.demo.server;
  2. interface ITaskCallback {
  3. void actionPerformed(int actionId);
  4. }
ITaskBinder.aidl 用于存放供给client端调用的方法
  2. import com.cmcc.demo.server.ITaskCallback;
  3. interface ITaskBinder {
  4. boolean isTaskRunning();
  5. void stopRunningTask();
  6. void registerCallback(ITaskCallback cb);
  7. void unregisterCallback(ITaskCallback cb);
  8. }
接着建立服务端,要实现回调,需要新建RemoteCallbackList对象(一个存储回调对象的列表),通过类似发送广播的形式来实现回调
MyService.java
  2. import com.cmcc.demo.server.ITaskBinder;
  3. import com.cmcc.demo.server.ITaskCallback;
  4. import android.app.Service;
  5. import android.content.Intent;
  6. import android.os.IBinder;
  7. import android.os.RemoteCallbackList;
  8. import android.os.RemoteException;
  9. import android.util.Log;
  10. public class MyService extends Service {
  11. private static final String TAG = "aidltest";
  12. @Override
  13. public void onCreate() {
  14. printf("service create");
  15. }
  16. @Override
  17. public void onStart(Intent intent, int startId) {
  18. printf("service start id=" + startId);
  19. callback(startId);
  20. }
  21. @Override
  22. public IBinder onBind(Intent t) {
  23. printf("service on bind");
  24. return mBinder;
  25. }
  26. @Override
  27. public void onDestroy() {
  28. printf("service on destroy");
  29. super.onDestroy();
  30. }
  31. @Override
  32. public boolean onUnbind(Intent intent) {
  33. printf("service on unbind");
  34. return super.onUnbind(intent);
  35. }
  36. public void onRebind(Intent intent) {
  37. printf("service on rebind");
  38. super.onRebind(intent);
  39. }
  40. private void printf(String str) {
  41. Log.v(TAG, "###################------ " + str + "------");
  42. }
  43. void callback(int val) {
  44. final int N = mCallbacks.beginBroadcast();
  45. for (int i=0; i<N; i++) {
  46. try {
  47. mCallbacks.getBroadcastItem(i).actionPerformed(val);
  48. }
  49. catch (RemoteException e) {
  50. // The RemoteCallbackList will take care of removing
  51. // the dead object for us.
  52. }
  53. }
  54. mCallbacks.finishBroadcast();
  55. }
  56. private final ITaskBinder.Stub mBinder = new ITaskBinder.Stub() {
  57. public void stopRunningTask() {
  58. }
  59. public boolean isTaskRunning() {
  60. return false;
  61. }
  62. public void registerCallback(ITaskCallback cb) {
  63. if (cb != null) {
  64. mCallbacks.register(cb);
  65. }
  66. }
  67. public void unregisterCallback(ITaskCallback cb) {
  68. if(cb != null) {
  69. mCallbacks.unregister(cb);
  70. }
  71. }
  72. };
  73. final RemoteCallbackList <ITaskCallback>mCallbacks = new RemoteCallbackList <ITaskCallback>();
  74. }
最后建立客户端,使用aidl,实现回调方法。
MyActivity.java
  1. package com.cmcc.demo;
  2. import android.app.Activity;
  3. import android.content.ComponentName;
  4. import android.content.Intent;
  5. import android.content.ServiceConnection;
  6. import android.os.Bundle;
  7. import android.os.IBinder;
  10. import android.view.View;
  11. import android.view.View.OnClickListener;
  12. import android.widget.Button;
  13. import com.cmcc.demo.server.*;
  14. public class MyActivity extends Activity {
  15. private static final String TAG = "aidltest";
  16. private Button btnOk;
  17. private Button btnCancel;
  18. @Override
  19. public void onCreate(Bundle icicle) {
  20. super.onCreate(icicle);
  21. setContentView(R.layout.test_service);
  22. btnOk = (Button)findViewById(R.id.btn_ok);
  23. btnCancel = (Button)findViewById(R.id.btn_cancel);
  24. btnOk.setText("Start Service");
  25. btnCancel.setText("Stop Service");
  26. btnCancel.setEnabled(false);
  27. btnOk.setOnClickListener(new OnClickListener() {
  28. public void onClick(View v) {
  29. onOkClick();
  30. }
  31. });
  32. btnCancel.setOnClickListener(new OnClickListener() {
  33. public void onClick(View v) {
  34. onCancelClick();
  35. }
  36. });
  37. }
  38. void onOkClick() {
  39. printf("send intent to start");
  40. Bundle args = new Bundle();
  41. Intent intent = new Intent("com.cmcc.demo.IMyService");
  42. intent.putExtras(args);
  43. startService(intent);
  44. //bindService(intent, mConnection, Context.BIND_AUTO_CREATE);
  45. btnCancel.setEnabled(true);
  46. }
  47. void onCancelClick() {
  48. printf("send intent to stop");
  49. //unbindService(mConnection);
  50. Intent intent = new Intent("com.cmcc.demo.IMyService");
  51. stopService(intent);
  52. btnCancel.setEnabled(false);
  53. }
  54. private void printf(String str) {
  55. Log.v(TAG, "###################------ " + str + "------");
  56. }
  57. ITaskBinder mService;
  58. private ServiceConnection mConnection = new ServiceConnection() {
  59. public void onServiceConnected(ComponentName className, IBinder service) {
  60. mService = ITaskBinder.Stub.asInterface(service);
  61. try {
  62. mService.registerCallback(mCallback);
  63. } catch (RemoteException e) {
  64. }
  65. }
  66. public void onServiceDisconnected(ComponentName className) {
  67. mService = null;
  68. }
  69. };
  70. private ITaskCallback mCallback = new ITaskCallback.Stub() {
  71. public void actionPerformed(int id) {
  72. printf("callback id=" + id);
  73. }
  74. };
  75. }
总结一下aidl的使用
AIDL的创建方法:
AIDL语法很简单,可以用来声明一个带一个或多个方法的接口,也可以传递参数和返回值。由于远程调用的需要, 这些参数和返回值并不是任何类型.下面是些AIDL支持的数据类型:
1. 不需要import声明的简单Java编程语言类型(int,boolean等)
2. String, CharSequence不需要特殊声明
3. List, Map和Parcelables类型, 这些类型内所包含的数据成员也只能是简单数据类型, String等其他比支持的类型.
(另外: 我没尝试Parcelables, 在Eclipse+ADT下编译不过, 或许以后会有所支持).
下面是AIDL语法:
// 文件名: SomeClass.aidl // 文件可以有注释, 跟java的一样 // 在package以前的注释, 将会被忽略. // 函数和变量以前的注释, 都会被加入到生产java代码中. package com.cmcc.demo;
// import 引入语句 import com.cmcc.demo.ITaskCallback;
//函数跟java一样, 可以有0到多个参数 ,可以有一个返回值 boolean isTaskRunning();
void stopRunningTask(); //参数可以是另外的一个aidl定义的接口 void registerCallback(ITaskCallback cb);
//参数可以是String, 可以用in表入输入类型, out表示输出类型.
int getCustomerList(in String branch, out String customerList);
实现接口时有几个原则:
.抛出的异常不要返回给调用者. 跨进程抛异常处理是不可取的.
.IPC调用是同步的。如果你知道一个IPC服务需要超过几毫秒的时间才能完成地话,你应该避免在Activity的主线程中调用。 也就是IPC调用会挂起应用程序导致界面失去响应. 这种情况应该考虑单起一个线程来处理.
.不能在AIDL接口中声明静态属性。
IPC的调用步骤:
1. 声明一个接口类型的变量,该接口类型在.aidl文件中定义。
2. 实现ServiceConnection。
3. 调用ApplicationContext.bindService(),并在ServiceConnection实现中进行传递.
4. 在ServiceConnection.onServiceConnected()实现中,你会接收一个IBinder实例(被调用的Service). 调用 YourInterfaceName.Stub.asInterface((IBinder)service)将参数转换为YourInterface类型。
5. 调用接口中定义的方法。 你总要检测到DeadObjectException异常,该异常在连接断开时被抛出。它只会被远程方法抛出。
6. 断开连接,调用接口实例中的ApplicationContext.unbindService()
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/52852186
