linux网络编程之地址结构sockaddr和sockaddr_in的区别
chenyu 发表于 2021/07/27 01:16:55 2021/07/27
【摘要】 1、介绍sockaddr 结构体struct sockaddr在/usr/include/linux/socket.h中定义   struct sockaddr { unsigned short sa_family; // 2 bytes address family, AF_xxx char sa_data[14]; // 14 bytes of proto...
1、介绍sockaddr
  1. struct sockaddr {
  2. unsigned short sa_family; // 2 bytes address family, AF_xxx
  3. char sa_data[14]; // 14 bytes of protocol address
  4. };
2、介绍sockaddr_in
结构体struct sockaddr_in在/usr/include/netinet/in.h中定义,是IPv4的地址结构
  1. struct sockaddr_in {
  2. short sin_family; // 2 bytes e.g. AF_INET, AF_INET6
  3. unsigned short sin_port; // 2 bytes e.g. htons(3490)
  4. struct in_addr sin_addr; // 4 bytes see struct in_addr, below
  5. char sin_zero[8]; // 8 bytes zero this if you want to
  6. };
  7. struct in_addr {
  8. unsigned long s_addr; // 4 bytes load with inet_pton()
  9. };
3、对比总结
struct sockaddr是通用的套接字地址,而struct sock
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/56481754
