java之解析DNS的SRV记录
【摘要】 1、导入相应的jar包
导入sjava-2.1.6.jar包,今天上传资源有问题,下次传了之后再补充到这里。
2、关键代码
public static List<String> resoveSrv(String query) { // String s...
1、导入相应的jar包
2、关键代码
// String s = "ramuh.example.com"; // the inputted string, I need to obtain the Port to be added to this
ArrayList<String> ret = new ArrayList<String>();
// String query = "_rdp._tcp." + s;
try{
Record[] records = new Lookup(query,Type.SRV).run(); // returning null
if(records != null && records.length > 0) {
for(Record r : records) {
SRVRecord srv = (SRVRecord)r;
String hostname = srv.getTarget().toString().replaceFirst("\\.$", "");
int port = srv.getPort();
ret.add(hostname + ":" + port);
return ret;
else{
return null;
} catch (TextParseException e) {
return null;
2、4行是注释掉的
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/58588545
cloudbbs@huaweicloud.com
