LeetCode之Reverse Integer
chenyu 发表于 2021/07/26 23:29:30 2021/07/26
【摘要】 1、题目 Reverse digits of an integer. Example1: x = 123, return 321Example2: x = -123, return -321 click to show spoilers. Note: The input is assumed to be a 32-bit signed inte...
1、题目
Note:
The input is assumed to be a 32-bit signed integer. Your function should return 0 when the reversed integer overflows.
Subscribe to see which companies asked this question.
2、代码实现
代码实现1、
通过不了LeetCode
  1. public static int reverse(int x) {
  2. if (x > Integer.MAX_VALUE || x < Integer.MIN_VALUE) {
  3. return 0;
  4. }
  5. boolean flag = false; //x是负数就是true,正数false
  6. if (x < 0) {
  7. flag = true;
  8. }
  9. String string = String.valueOf(x);
  10. String spliteStr = flag ? string.substring(1) : string;
  11. StringBuffer sb = new StringBuffer(spliteStr);
  12. sb = sb.reverse();
  13. String result = sb.toString();
  14. result = flag ? "-" + result : result;
  15. long value = Long.valueOf(result);
  16. if (value > Integer.MAX_VALUE || value < Integer.MIN_VALUE) {
  17. return 0;
  18. }
  19. return (int)value;
  20. }
代码实现二、
通过不了LeetCode
  1. public static int reverse1(int x) {
  3. return 0;
  4. }
  5. long result = 0;
  6. int temp = Math.abs(x);
  7. while (temp > 0) {
  8. result *= 10;
  9. result = result + temp % 10;
  10. temp /= 10;
  11. }
  12. if (result > Integer.MAX_VALUE ||result<Integer.MIN_VALUE ) {
  13. return 0;
  14. }
  15. return (int)(x >= 0 ? result : -result);
  16. }
代码实现三
可以通过LeetCode
  1. public static int reverse3(int n) {
  2. if (n > Integer.MAX_VALUE || n < Integer.MIN_VALUE) {
  3. return 0;
  4. }
  5. //输出结果定义为long
  6. long sum=0;
  7. while (n != 0) {
  8. int s = n % 10;
  9. sum = sum * 10 + s;
  10. n = n / 10;
  11. }
  12. //防止溢出操作
  13. if (sum > Integer.MAX_VALUE || sum < Integer.MIN_VALUE) {
  14. return 0;
  15. }
  16. return (int)sum;
  17. }
注意有溢出问题,对比分析,第一个实现和第二个实现 不越界没问题。
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/65631346
