LeetCode之Reverse String
chenyu 发表于 2021/07/27 01:50:05 2021/07/27
【摘要】 1、题目: Write a function that takes a string as input and returns the string reversed. Example: Given s = "hello", return "olleh".   2、代码实现: 代码实现1: public static S...
1、题目:
Example:
2、代码实现:
代码实现1:
  1. public static String reverseString(String s) {
  2. if (s == null) {
  3. return null;
  4. }
  5. if (s.length() == 0) {
  6. return "";
  7. }
  8. int length = s.length();
  9. char[] chars = s.toCharArray();
  10. String result = "";
  11. for (int i = chars.length - 1; i >=0; --i) {
  12. result += chars[i];
  13. }
  14. return result;
  15. }
代码实现2:
  1. public String reverseString(String s) {
  2. return new StringBuffer(s).reverse().toString();
  3. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/65661702
