LeetCode之Island Perimeter
chenyu 发表于 2021/07/26 23:59:22 2021/07/26
【摘要】 1、题目 You are given a map in form of a two-dimensional integer grid where 1 represents land and 0 represents water. Grid cells are connected horizontally/vertically (not diagonally). The...
1、题目
You are given a map in form of a two-dimensional integer grid where 1 represents land and 0 represents water. Grid cells are connected horizontally/vertically (not diagonally). The grid is completely surrounded by water, and there is exactly one island (i.e., one or more connected land cells). The island doesn't have "lakes" (water inside that isn't connected to the water around the island). One cell is a square with side length 1. The grid is rectangular, width and height don't exceed 100. Determine the perimeter of the island.
Example:
  1. [[0,1,0,0],
  2. [1,1,1,0],
  3. [0,1,0,0],
  4. [1,1,0,0]]
  5. Answer: 16
  6. Explanation: The perimeter is the 16 yellow stripes in the image below:
2、代码实现
  1. public class Solution {
  2. public int islandPerimeter(int[][] grid) {
  3. if (grid == null)
  4. return 0;
  5. //gril.length就是行数 row,grid.length就是列数gril
  6. int row = grid.length;
  7. int col = grid[0].length;
  8. int sum = 0, count = 0;
  9. for (int i = 0; i < row; ++i) {
  10. for (int j = 0; j < col; ++j) {
  11. if (grid[i][j] == 1) {
  12. if (i - 1 == -1) {
  13. count++;
  14. } else {
  15. if (grid[i - 1][j] == 0) {
  16. count++;
  17. }
  18. }
  19. if (i + 1 == row) {
  20. count++;
  21. } else {
  22. if (grid[i + 1][j] == 0) {
  23. count++;
  24. }
  25. }
  26. if (j - 1 == -1) {
  27. count++;
  28. } else {
  29. if (grid[i][j - 1] == 0) {
  30. count++;
  31. }
  32. }
  33. if (j + 1 == col) {
  34. count++;
  35. } else {
  36. if (grid[i][j + 1] == 0) {
  37. count++;
  38. }
  39. }
  40. }
  41. }
  42. }
  43. return count;
  44. }
  45. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/66472228
