LeetCode之Single Number
chenyu 发表于 2021/07/27 00:27:58 2021/07/27
【摘要】 1、题目 Given an array of integers, every element appears twice except for one. Find that single one. Note: Your algorithm should have a linear runtime complexity. Could you im...
1、题目
Note:
Your algorithm should have a linear runtime complexity. Could you implement it without using extra memory?
Subscribe to see which companies asked this question.
2、代码实现
代码实现1
  1. public static int singleNumber1(int nums[]) {
  2. if (nums == null)
  3. return 0;
  4. int length = nums.length;
  5. int count = 0;
  6. for (int i = 0; i < length ; i++) {
  7. for (int j = 0; j < length; j++) {
  8. if (i != j) {
  9. if (nums[i] == nums[j])
  10. continue;
  11. else {
  12. count++;
  13. }
  14. }
  15. }
  16. if (count == length - 1)
  17. return nums[i];
  18. count = 0;
  19. }
  20. return 0;
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/67642158
