LeetCode之Max Consecutive Ones
chenyu 发表于 2021/07/27 01:37:29 2021/07/27
【摘要】 1、题目 Given a binary array, find the maximum number of consecutive 1s in this array. Example 1: Input: [1,1,0,1,1,1]Output: 3Explanation: The first two digits or the last three digit...
1、题目
Example 1:
  1. Input: [1,1,0,1,1,1]
  2. Output: 3
  3. Explanation: The first two digits or the last three digits are consecutive 1s.
  4. The maximum number of consecutive 1s is 3.
Note:
  • The input array will only contain 0 and 1.
  • The length of input array is a positive integer and will not exceed 10,000
2、代码实现
  1. public class Solution {
  2. public int findMaxConsecutiveOnes(int[] nums) {
  3. if (nums == null) {
  4. return 0;
  5. }
  6. int zero = 0;
  7. for (int i = 0; i < nums.length; i++) {
  8. if (nums[i] == 0) {
  9. ++zero;
  10. }
  11. }
  12. if (zero == nums.length) {
  13. return 0;
  14. }
  15. int count = 0;
  16. int maxValue = 0;
  17. int maxLength = 0;
  18. for (int i = 0; i < nums.length; ++i) {
  19. if (nums[i] > maxValue) {
  20. maxValue = nums[i];
  21. }
  22. }
  23. for (int i = 0; i < nums.length; ++i) {
  24. if (nums[i] == maxValue) {
  25. for (int j = i; j < nums.length; ++j) {
  26. if (nums[j] == maxValue) {
  27. count++;
  28. } else {
  29. break;
  30. }
  31. }
  32. if (maxLength < count) {
  33. maxLength = count;
  34. }
  35. count = 0;
  36. }
  37. }
  38. return maxLength;
  39. }
  40. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/66473124
