LeetCode之Hamming Distance
chenyu 发表于 2021/07/26 23:57:44 2021/07/26
【摘要】 1、题目 The Hamming distance between two integers is the number of positions at which the corresponding bits are different. Given two integers x and y, calculate...
1、题目
Given two integers x and y, calculate the Hamming distance.
Note:
0 ≤ x, y < 231.
Example:
  1. Input: x = 1, y = 4
  2. Output: 2
  3. Explanation:
  4. 1 (0 0 0 1)
  5. 4 (0 1 0 0)
  6. ↑ ↑
  7. The above arrows point to positions where the corresponding bits are different.
题意:
给定两个整数x,y,计算x和y的汉明距离。汉明距离是指x、y的二进制表示中,相同位置上数字不相同的所有情况数。
2、代码实现
  1. public class Solution {
  2. public int hammingDistance(int x, int y) {
  3. int notSame = x ^ y;
  4. int count = 0;
  5. while (notSame != 0) {
  6. if (notSame % 2 == 1)
  7. ++count;
  8. notSame /= 2;
  9. }
  10. return count;
  11. }
  12. }
注意记得用 异或
0 ^ 1 = 1
1 ^ 0 = 1
1 ^ 1 = 0
0 ^ 0 = 0
然后就是我们平时10进制的话,每次去掉末尾的数字是 / 10,二进制的话就是/2,切记。
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/65668790
