LeetCode之Remove Duplicates from Sorted Array II
chenyu 发表于 2021/07/27 00:10:53 2021/07/27
【摘要】 1、题目 Follow up for "Remove Duplicates": What if duplicates are allowed at most twice? For example, Given sorted array nums = [1,1,1,2,2,3], Your function should ...
1、题目
For example,
Your function should return length = 5, with the first five elements of nums being 1, 1, 2, 2 and 3. It doesn't matter what you leave beyond the new length.
2、代码实现
  1. public class Solution {
  2. public int removeDuplicates(int[] nums) {
  3. if (null == nums || nums.length == 0) {
  4. return 0;
  5. }
  6. int length = nums.length;
  7. int newLen = 1;
  8. int count = 1;
  9. for (int i = 1; i < length; ++i) {
  10. if (nums[i] == nums[i - 1]) {
  11. count++;
  12. if (count <= 2) {
  13. nums[newLen++] = nums[i];
  14. }
  15. } else {
  16. count = 1;
  17. nums[newLen++] = nums[i];
  18. }
  19. }
  20. return newLen;
  21. }
  22. }
3、总结
既然看到连续相等,那我们就要想到前后两个不相等作为条件,然后加上通过一个变量不超过2个就可以了
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/66478557
