LeetCode之Excel Sheet Column Number
chenyu 发表于 2021/07/27 00:40:05 2021/07/27
【摘要】 1、题目   Related to question Excel Sheet Column Title Given a column title as appear in an Excel sheet, return its corresponding column number. For example: A -> 1 B -> 2 C ...
1、题目
For example:
  1. A -> 1
  2. B -> 2
  3. C -> 3
  4. ...
  5. Z -> 26
  6. AA -> 27
  7. AB -> 28
Credits:
Special thanks to @ts for adding this problem and creating all test cases.
Subscribe to see which companies asked this question.
2、分析
  1. A -> 1*26^0
  2. AA -> 1*26^1 + 1*26^0
  3. AAA -> 1*26^2 + 1*26^1 + 1*26^0
3、代码实现
  1. public class Solution {
  2. public int titleToNumber(String value) {
  3. if (value == null || value.length() == 0)
  4. return 0;
  5. int length = value.length();
  6. //A 65
  7. char[] chars = value.toCharArray();
  8. int result = 0;
  9. int pow = 0;
  10. //please here is i >= 0 not is i > 0
  11. for (int i = length - 1; i >= 0; i--) {
  12. int tmp = chars[i] - 'A' + 1;
  13. int temp1 = (int)Math.pow(26, pow);
  14. pow++;
  15. result += tmp * temp1;
  16. }
  17. return result;
  18. }
  19. }
4、总结
注意每次写
for(int i = length - 1; i > 0 --i)
的时候要注意不是这样写的,需要写成这样
for(int i = length - 1; i >= 0 --i)
不要忘记有=号,切记,以后不要换这样的错误。
还有求^的函数要知道,不要忘记
Math.pow(26, pow)
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/68950225
