LeetCode之Missing Number
chenyu 发表于 2021/07/26 23:01:31 2021/07/26
【摘要】 1、题目 Given an array containing n distinct numbers taken from 0, 1, 2, ..., n, find the one that is missing from the array. For example, Given nums = [0, ...
1、题目
For example,
Given nums = [0, 1, 3] return 2.
Given  nums  =  [0]  return  1
2、代码实现
  1. public class Solution {
  2. public int missingNumber(int[] nums) {
  3. if (nums == null) {
  4. return 0;
  5. }
  6. int result = 0;
  7. Map<Integer, Integer> map = new HashMap<Integer, Integer>();
  8. for (int i = 0; i < nums.length; ++i) {
  9. map.put(nums[i], 2);
  10. }
  11. for (int i = 0; i <= nums.length; ++i) {
  12. Integer in = map.get(i);
  13. if (in == null) {
  14. return i;
  15. }
  16. }
  17. return result;
  18. }
  19. }
3、注意的地方
这个地方需要注意
  4. return i;
  5. }
  6. }
一定要记得写 i <= nums.length ,不是i < length
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/68061218
