LeetCode之Ransom Note
chenyu 发表于 2021/07/27 00:17:22 2021/07/27
【摘要】 1、题目 Given an arbitrary ransom note string and another string containing letters from all the magazines, write a function that will return true if the ransom note can be constructed fro...
1、题目
Given an arbitrary ransom note string and another string containing letters from all the magazines, write a function that will return true if the ransom note can be constructed from the magazines ; otherwise, it will return false.
Each letter in the magazine string can only be used once in your ransom note.
Note:
You may assume that both strings contain only lowercase letters.
  1. canConstruct("a", "b") -> false
  2. canConstruct("aa", "ab") -> false
  3. canConstruct("aa", "aab") -> true
2、代码实现
  1. public class Solution {
  2. public boolean canConstruct(String ransomNote, String magazine) {
  3. if (magazine == null)
  4. return false;
  5. if (ransomNote == null)
  6. return false;
  7. if (ransomNote.length() == 0 && magazine.length() == 0)
  8. return true;
  9. List<Character> list = new ArrayList<Character>();
  10. for (char c : magazine.toCharArray()) {
  11. list.add(Character.valueOf(c));
  12. }
  13. if (ransomNote.length() == magazine.length()) {
  14. for (int i = 0; i < ransomNote.length(); i++) {
  15. if (!list.remove(Character.valueOf(ransomNote.charAt(i)))) {
  16. return false;
  17. }
  18. }
  19. return true;
  20. } else {
  21. for (int i = 0; i < ransomNote.length(); i++) {
  22. if (!list.remove(Character.valueOf(ransomNote.charAt(i)))) {
  23. return false;
  24. }
  25. }
  26. if (list.size() > 0) {
  27. return true;
  28. }
  29. }
  30. return false;
  31. }
  32. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/68485900
