LeetCode之Add Digits
chenyu 发表于 2021/07/27 01:37:28 2021/07/27
【摘要】 1、题目 Given a non-negative integer num, repeatedly add all its digits until the result has only one digit. For example: Given num = 38, the process is like: 3 + 8 = 11...
1、题目
For example:
Given num = 38, the process is like: 3 + 8 = 11, 1 + 1 = 2. Since 2 has only one digit, return it.
2、代码实现
  1. public class Solution {
  2. public int getAllSum(int val) {
  3. int sum = 0;
  4. while (val > 0) {
  5. sum += val % 10;
  6. val /= 10;
  7. }
  8. return sum;
  9. }
  10. public int addDigits(int num) {
  11. if (num <= 0)
  12. return 0;
  13. while (num >= 10) {
  14. num = getAllSum(num);
  15. }
  16. return num;
  17. }
  18. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/68488700
