LeetCode之Sqrt(x)
chenyu 发表于 2021/07/27 01:34:58 2021/07/27
【摘要】 1、题目 Implement int sqrt(int x). Compute and return the square root of x. Subscribe to see which companies asked this question. 2、代码实现 public class...
1、题目
2、代码实现
  1. public class Solution {
  2. public int mySqrt(int x) {
  3. if (x < 0)
  4. return -1;
  5. if (x == 0)
  6. return 0;
  7. if (x == 1)
  8. return 1;
  9. int max = x / 2 + 1;
  10. int min = 1;
  11. while (min <= max) {
  12. int mid = (min + max) / 2;
  13. if (mid <= x / mid && x / (mid + 1) < mid + 1)
  14. return mid;
  15. if (mid > x / mid)
  16. max = mid - 1;
  17. else
  18. min = mid + 1;
  19. }
  20. return 0;
  21. }
  22. }
3、注意的地方
1)、第一要记得判断条件是
mid * mid <= x && (mid + 1) * (mid + 1) >x
2)、第二要防止数据超过整形数据范围,所以需要把条件转化为
3)、逻辑要清晰,先求max,min, next we will get mid, and condition is mid * mid <= x && (mid + 1) * (mid + 1) > x, and by condition ,do not remember max = mid -1, min = mid +1 or max = mid, min = mid;
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/70042243
