LeetCode之Two Sum II - Input array is sorted
chenyu 发表于 2021/07/26 23:19:18 2021/07/26
【摘要】 1、题目   Given an array of integers that is already sorted in ascending order, find two numbers such that they add up to a specific target number. The function twoSum should return in...
1、题目
The function twoSum should return indices of the two numbers such that they add up to the target, where index1 must be less than index2. Please note that your returned answers (both index1 and index2) are not zero-based.
You may assume that each input would have exactly one solution and you may not use the same element twice.
Input: numbers={2, 7, 11, 15}, target=9
Output: index1=1, index2=2
Subscribe to see which companies asked this question.
2、代码实现
  1. public class Solution {
  2. public int[] twoSum(int[] nums, int target) {
  3. if (null == nums)
  4. return null;
  5. int[] result = new int[2];
  6. HashMap<Integer, Integer> map = new HashMap<Integer, Integer>();
  7. for (int i = 0; i < nums.length; ++i) {
  8. Integer value = map.get(nums[i]);
  9. if (null == value)
  10. map.put(nums[i], i);
  11. Integer index = map.get(target - nums[i]);
  12. if (null != index && index < i)
  13. {
  14. result[0] = index + 1;
  15. result[1] = i + 1;
  16. }
  17. }
  18. return result;
  19. }
  20. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/69810329
