Android之如何让Android studio编译更快
chenyu 发表于 2021/07/27 00:26:42 2021/07/27
【摘要】 1、 开启gradle单独的守护进程 在下面的目录下面创建gradle.properties文件   /home/<username>/.gradle/ (Linux)/Users/<username>/.gradle/ (Mac)C:\Users\<username>\.gradle (Wind...
1、 开启gradle单独的守护进程
  1. /home/<username>/.gradle/ (Linux)
  2. /Users/<username>/.gradle/ (Mac)
  3. C:\Users\<username>\.gradle (Windows)
最好是从一个项目里面拷贝过来然后修改下
  1. #Project-wide Gradle settings.
  2. # IDE (e.g. Android Studio) users:
  3. # Settings specified in this file will override any Gradle settings
  4. # configured through the IDE.
  5. # For more details on how to configure your build environment visit
  6. # http://www.gradle.org/docs/current/userguide/build_environment.html
  7. # The Gradle daemon aims to improve the startup and execution time of Gradle.
  8. # When set to true the Gradle daemon is to run the build.
  9. # TODO: disable daemon on CI, since builds should be clean and reliable on servers
  10. org.gradle.daemon=true
  11. # Specifies the JVM arguments used for the daemon process.
  12. # The setting is particularly use
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/70245095
