LeetCode之Valid Parentheses
chenyu 发表于 2021/07/27 01:40:56 2021/07/27
【摘要】 1、题目 Given a string containing just the characters '(', ')', '{', '}', '[' and ']', determine if the input string is valid. The brackets must close i...
1、题目
The brackets must close in the correct order, "()" and "()[]{}" are all valid but "(]" and "([)]" are not.
2、思路
用stack来实现,左边的进栈,如果是右边的出栈,发现没有或者不匹配就返回false
3、代码实现
  1. public class Solution {
  2. public boolean isValid(String s) {
  3. if (s == null || s.length() == 0) {
  4. return false;
  5. }
  6. char chars[] = s.toCharArray();
  7. Stack<Character> stack = new Stack<Character>();
  8. for (int i = 0; i < chars.length; ++i) {
  9. if (chars[i] == '(' || chars[i] == '{' || chars[i] == '[') {
  10. stack.add(chars[i]);
  11. } else {
  12. if (!stack.isEmpty()) {
  13. Character value = stack.pop();
  14. if (chars[i] == ')') {
  15. if (value != '(')
  16. return false;
  17. }
  18. if (chars[i] == '}') {
  19. if (value != '{')
  20. return false;
  21. }
  22. if (chars[i] == ']') {
  23. if (value != '[')
  24. return false;
  25. }
  26. } else {
  27. return false;
  28. }
  29. }
  30. }
  31. return stack.isEmpty();
  32. }
  33. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/77104503
