LeetCode之Sum of Left Leaves
chenyu 发表于 2021/07/27 01:24:33 2021/07/27
【摘要】 1、题目 Find the sum of all left leaves in a given binary tree. Example: 3 / \ 9 20 / \ 15 7 There are two left leaves in the binary tree, with values 9 and 15 respectively. ...
1、题目
Example:
  1. 3
  2. / \
  3. 9 20
  4. / \
  5. 15 7
  6. There are two left leaves in the binary tree, with values 9 and 15 respectively. Return 24.
Subscribe to see which companies asked this question.
2、代码实现
  1. /**
  2. * Definition for a binary tree node.
  3. * public class TreeNode {
  4. * int val;
  5. * TreeNode left;
  6. * TreeNode right;
  7. * TreeNode(int x) { val = x; }
  8. * }
  9. */
  10. public class Solution {
  11. public int sumOfLeftLeaves(TreeNode head) {
  12. if (head == null) return 0;
  13. int left = 0, right = 0;
  14. if (head.left != null && head.left.left == null && head.left.right == null) {
  15. left = head.left.val;
  16. } else {
  17. left = sumOfLeftLeaves(head.left);
  18. }
  19. right = sumOfLeftLeaves(head.right);
  20. return left + right;
  21. }
  22. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/73065840
