LeetCode之Rotate Array
chenyu 发表于 2021/07/27 01:40:06 2021/07/27
【摘要】 1、题目 Rotate an array of n elements to the right by k steps. For example, with n = 7 and k = 3, the array [1,2,3,4,5,6,7] is rotated t...
1、题目
For example, with n = 7 and k = 3, the array [1,2,3,4,5,6,7] is rotated to [5,6,7,1,2,3,4].
Note:
Try to come up as many solutions as you can, there are at least 3 different ways to solve this problem.
[show hint]
Related problem: Reverse Words in a String II
Credits:
Special thanks to @Freezen for adding this problem and creating all test cases.
2、结题思路
1、先得到有效的k,
2、反转所有数组
3、反转下标从0到k的数组
4、 反转下标从k到length - 1的数组
3、代码实现
  1. class Solution {
  2. public void rotate(int[] nums, int k) {
  3. if (nums == null || nums.length == 0 || k <= 0)
  4. return;
  5. int length = nums.length;
  6. int lastK = 0;
  7. if (k < length)
  8. lastK = k;
  9. else
  10. lastK = k % length;
  11. if (lastK == 0)
  12. return;
  13. change(nums, length);
  14. change(nums, lastK);
  15. int i = lastK, j = length - 1;
  16. while (i < j) {
  17. int temp = nums[i];
  18. nums[i] = nums[j];
  19. nums[j] = temp;
  20. i++;
  21. j--;
  22. }
  23. }
  24. public void change(int[] nums, int length) {
  25. for (int i = 0; i < length / 2; ++i) {
  26. int temp = nums[i];
  27. nums[i] = nums[length - i - 1];
  28. nums[length - i - 1] = temp;
  29. }
  30. }
  31. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/78014922
