Git提示Please move or remove them before you switch branches.
chenyu 发表于 2021/07/26 23:27:30 2021/07/26
【摘要】 1 问题 git checkout V1 提示错误如下 error: The following untracked working tree files would be overwritten by checkout: flutter_module/pubspec.lockPlease move or remove them before you switch br...
1 问题
git checkout V1
提示错误如下
  1. error: The following untracked working tree files would be overwritten by checkout:
  2. flutter_module/pubspec.lock
  3. Please move or remove them before you switch branches.
  4. Aborting
2 解决办法
git clean -df ../flutter_module/pubspec.lock
然后再
git checkout V1
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/107202845
