LeetCode之First Unique Character in a String
chenyu 发表于 2021/07/27 00:10:13 2021/07/27
【摘要】 1、题目 Given a string, find the first non-repeating character in it and return it's index. If it doesn't exist, return -1. Examples: s = "leetcode"return 0. s = "loveleetcode",return ...
1、题目
Examples:
  1. s = "leetcode"
  2. return 0.
  3. s = "loveleetcode",
  4. return 2.
2、代码实现
  1. public class Solution {
  2. public int firstUniqChar(String s) {
  3. if (s == null || s.length() == 0) {
  4. return -1;
  5. }
  6. HashMap<Character, Integer> map = new HashMap<Character, Integer>();
  7. for (int i = 0; i < s.length(); i++) {
  8. Integer in = map.get(s.charAt(i));
  9. if (in == null)
  10. map.put(s.charAt(i), 1);
  11. else
  12. map.put(s.charAt(i), 2);
  13. }
  14. for (int i = 0; i < s.length(); i++) {
  15. if(map.get(s.charAt(i)) == 2) {
  16. continue;
  17. } else {
  18. if (map.get(s.charAt(i)) == 1) {
  19. return i;
  20. }
  21. }
  22. }
  23. return -1;
  24. }
  25. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/67723555
