Android studio之编译提示Could not find :umeng-asms-v1.2.1:.
chenyu 发表于 2021/07/26 22:54:28 2021/07/26
【摘要】 1 、问题 Could not determine the dependencies of task ':app:compileDebugJavaWithJavac'.> Could not resolve all task dependencies for configuration ':app:debugCompileClasspath'. > Coul...
1 、问题
  1. Could not determine the dependencies of task ':app:compileDebugJavaWithJavac'.
  2. > Could not resolve all task dependencies for configuration ':app:debugCompileClasspath'.
  3. > Could not find :umeng-asms-v1.2.1:.
  4. Required by:
  5. project :app
  6. > Could not find :umeng-apm-v1.2.0:.
  7. Required by:
  8. project :app
  9. Possible solution:
  10. - Declare repository providing the artifact, see the documentation at https://docs.gradle.org/current/userguide/declaring_repositories.html
只要提示这种Could not find :可能arr包没有引入正确,可能少了
  1. flatDir{
  2. dirs 'libs'
  3. }
2 、解决办法
导入正确的aar文件和jar包正确姿势如下
app的build.gradle文件下面
  1. implementation files('libs/umeng-common-9.3.8.jar')
  2. implementation(name: 'umeng-asms-v1.2.1', ext: 'aar')
  3. implementation(name: 'umeng-apm-v1.2.0', ext: 'aar')
  4. repositories {
  5. flatDir{
  6. dirs 'libs'
  7. }
  8. }
文章来源: chenyu.blog.csdn.net,作者:chen.yu,版权归原作者所有,如需转载,请联系作者。
原文链接:chenyu.blog.csdn.net/article/details/116796034
