GuassDB(DWS)的连接类型介绍
wangxiaojuan8 发表于 2021/07/24 17:04:41 2021/07/24
【摘要】 连接类型介绍想要通过SQL完成各种复杂的查询,则多表之间的连接是必不可少的。连接分为:内连接和外连接两大类,每大类中还可进行细分。为了能更好的说明各种连接之间的区别,下面通过具体示例进行各连接的展示。首先做如下表创建和设置:CREATE TABLE student( id INTEGER, name varchar(50));CREATE TABLE math_score( id IN...
连接类型介绍
首先做如下表创建和设置:
  id INTEGER,
  name varchar(50)
  id INTEGER,
  score INTEGER
INSERT INTO student VALUES(1, 'Tom');
INSERT INTO student VALUES(2, 'Lily');
INSERT INTO student VALUES(3, 'Tina');
INSERT INTO student VALUES(4, 'Perry');
INSERT INTO math_score VALUES(1, 80);
INSERT INTO math_score VALUES(2, 75);
INSERT INTO math_score VALUES(4, 95);
INSERT INTO math_score VALUES(6, NULL);
Set enable_fast_query_shipping = off;
Set explain_perf_mode = pretty;
1. 内连接
  • 标准内连接(INNER JOIN)
    语法:left_table [INNER] JOIN right_table [ ON join_condition | USING ( join_column )]
    说明:表示left_table和rignt_table中满足join_condition的行拼接在一起作为结果输出,不满足条件的元组不会输出。
    示例1:查询学生的数学成绩
postgres=# Select s.id, s.name, ms.score from student s join math_score ms on s.id = ms.id;
 id | name  | score
  1 | Tom   |    80
  2 | Lily  |    75
  4 | Perry |    95
(3 rows)
postgres=# explain Select s.id, s.name, ms.score from student s join math_score ms on s.id = ms.id;
                                 QUERY PLAN
  id |               operation                | E-rows | E-width | E-costs
   1 | ->  Streaming (type: GATHER)           |     30 |     126 | 36.59
   2 |    ->  Hash Join (3,4)                 |     30 |     126 | 28.59
   3 |       ->  Seq Scan on student s        |     30 |     122 | 14.14
   4 |       ->  Hash                         |     29 |       8 | 14.14
   5 |          ->  Seq Scan on math_score ms |     30 |       8 | 14.14
 Predicate Information (identified by plan id)
   2 --Hash Join (3,4)
         Hash Cond: (s.id = ms.id)
(12 rows)
  • 交叉连接(CROSS JOIN)
    语法:left_table CROSS JOIN right_table
    说明:表示left_table中所有行和right_table中的所有行分别进行连接,最终结果行数等于两边行数的乘积。又称笛卡尔积。
    示例2:学生表和数学成绩表的交叉连接
postgres=# select s.id, s.name, ms.score from student s cross join math_score ms;
 id | name  | score
  1 | Tom   |    80
  1 | Tom   |    75
  1 | Tom   |    95
  2 | Lily  |    80
  2 | Lily  |    75
  2 | Lily  |    95
  4 | Perry |    80
  4 | Perry |    75
  4 | Perry |    95
  3 | Tina  |    80
  3 | Tina  |    75
  3 | Tina  |    95
  3 | Tina  |
  1 | Tom   |
  2 | Lily  |
  4 | Perry |
(16 rows)
postgres=# explain select s.id, s.name, ms.score from student s cross join math_score ms;
                                 QUERY PLAN
   1 | ->  Streaming (type: GATHER)           |    900 |     126 | 74.85
   2 |    ->  Nested Loop (3,5)               |    900 |     126 | 37.35
   3 |       ->  Streaming(type: BROADCAST)   |     90 |     122 | 17.93
   4 |          ->  Seq Scan on student s     |     30 |     122 | 14.14
   5 |       ->  Materialize                  |     30 |       4 | 14.21
   6 |          ->  Seq Scan on math_score ms |     30 |       4 | 14.14
(8 rows)
  • 自然连接(NATURAL JOIN)
    语法:left_table NATURAL JOIN right_table
    说明:表示left_table和right_table中列名相同的列进行等值连接,且自动将同名列只保留一份。
    示例3:学生表和数学成绩表的自然连接,两表的同名列为id列,将按照id列进行等值连接
postgres=# select * from student s natural join math_score ms;
 id | name  | score
  1 | Tom   |    80
  2 | Lily  |    75
  4 | Perry |    95
(3 rows)
postgres=# explain select * from student s natural join math_score ms;
                                 QUERY PLAN
   2 --Hash Join (3,4)
(12 rows)
2. 外连接
  • 左外连接
    语法:left_table LEFT [OUTER] JOIN right_table [ ON join_condition | USING ( join_column )]
    说明:左外连接的结果集包括left_table的所有行,而不仅仅是连接列所匹配的行。如果left_table的某行在right_table中没有匹配行,则在相关联的结果集行中输出right_table的列均为空值。
    示例4:学生表和数学成绩表进行左外连接,学生表中id为3的行在结果集中对应的右表数据用NULL填充
postgres=# select s.id, s.name, ms.score from student s left join math_score ms on (s.id = ms.id);
 id | name  | score
  3 | Tina  |
  1 | Tom   |    80
  2 | Lily  |    75
  4 | Perry |    95
(4 rows)
postgres=# explain select s.id, s.name, ms.score from student s left join math_score ms on (s.id = ms.id);
                                 QUERY PLAN
   2 |    ->  Hash Left Join (3, 4)           |     30 |     126 | 28.59
   2 --Hash Left Join (3, 4)
(12 rows)
  • 右外连接
    语法:left_table RIGHT [OUTER] JOIN right_table [ ON join_condition | USING ( join_column )]
    说明:与左外连接相反,右外连接的结果集包括right_table的所有行,而不仅仅是连接列所匹配的行。如果right_table的某行在left_table中没有匹配行,则在相关联的结果集行中left_table的列均为空值。
    示例5:学生表和数学成绩表进行右外连接,数学成绩表中id为6的行在结果集中对应的左表数据用NULL填充
postgres=# select ms.id, s.name, ms.score from student s right join math_score ms on (s.id = ms.id);
 id | name  | score
  6 |       |
  1 | Tom   |    80
  2 | Lily  |    75
  4 | Perry |    95
(4 rows)
postgres=# explain select ms.id, s.name, ms.score from student s right join math_score ms on (s.id = ms.id);
                               QUERY PLAN
   3 |       ->  Seq Scan on math_score ms |     30 |       8 | 14.14
   4 |       ->  Hash                      |     29 |     122 | 14.14
   5 |          ->  Seq Scan on student s  |     30 |     122 | 14.14
         Hash Cond: (ms.id = s.id)
(12 rows)
  • 全外连接
    语法:left_table FULL [OUTER] JOIN right_table [ ON join_condition | USING ( join_column )]
    说明:全外连接是左外连接和右外连接的综合。全外连接的结果集包括left_table和right_table的所有行,而不仅仅是连接列所匹配的行。如果left_table的某行在right_table中没有匹配行,则在相关联的结果集行中right_table的列均为空值。如果right_table的某行在left_table中没有匹配行,则在相关联的结果集行中left_table的列均为空值。
    示例6:学生表和数学成绩表进行全外外连接,学生表中id为3的行在结果集中对应的右表数据用NULL填充,数学成绩表中id为6的行在结果集中对应的左表数据用NULL填充
postgres=# select s.id, s.name, ms.id, ms.score from student s full join math_score ms on (s.id = ms.id);
 id | name  | id | score
  3 | Tina  |    |
  1 | Tom   |  1 |    80
  2 | Lily  |  2 |    75
  4 | Perry |  4 |    95
    |       |  6 |
(5 rows)
postgres=# explain select s.id, s.name, ms.id, ms.score from student s full join math_score ms on (s.id = ms.id);
                                 QUERY PLAN
   1 | ->  Streaming (type: GATHER)           |     30 |     130 | 36.59
   2 |    ->  Hash Full Join (3, 4)           |     30 |     130 | 28.59
   2 --Hash Full Join (3, 4)
(12 rows)
细心的朋友从上面示例的查询计划中不难发现,外连接在查询计划中的join算子中,相应的左外连接和全外连接会显示Left或Full字眼,而对于右外连接,在join算子中却显示的是Left。这是因为,右外连接其实就是将左右表进行交互后的左外连接,所以数据库内部实现为了减少处理逻辑,会将右外连接转为左外连接。
多表查询中on条件和where条件的区别
从上面各种连接语法中可见,除自然连接和交叉连接外,其他都需要有on条件(using在查询解析过程中会被转为on条件)来限制两表连接的结果。通常在查询的语句中也都会有where条件限制查询结果。这里说的on连接条件和where过滤条件是指不含可以下推到表上的过滤条件。那么on和where的区别是什么呢?on条件是两表连接的约束条件,where是对两表连接后产生的结果集再次进行过滤。简单说就是on条件优先于where条件,在两表进行连接时被应用;生成两表连接结果集后,再应用where条件。
想了解GuassDB(DWS)更多信息,欢迎微信搜索“GaussDB DWS”关注微信公众号,和您分享最新最全的PB级数仓黑科技,后台还可获取众多学习资料哦~
