代码挑战: 最大子数组 #C++
Jet Ding 发表于 2021/07/23 16:15:51 2021/07/23
【摘要】 Given an integer array nums, find the contiguous subarray (containing at least one number) which has the largest sum and return its sum.Example:Input: [-2,1,-3,4,-1,2,1,-5,4],Output: 6Explanation: ...
Example:
Output: 6
Explanation: [4,-1,2,1] has the largest sum = 6.
方案:
class Solution
public:
    int maxSubArray(vector<int> &nums)
        int result = nums[0];
        int temp = nums[0];
        for (int i = 1; i < nums.size(); i++)
            temp = max(nums[i], temp + nums[i]);
            result = max(result, temp);
        return result;
测试案例:
    TEST_METHOD(TestMethod1) {
        Solution solution;
        int numsArray[] = { -2, -3, 4, -1, -2, 1, 5, -3 };
        vector<int> nums;
        nums.insert(nums.begin(), std::begin(numsArray), std::end(numsArray));
        Assert::AreEqual(7, solution.maxSubArray(nums));
    } // namespace UnitTest1
    TEST_METHOD(TestMethod2)
        int numsArray[] = { -2, 1, -3, 4, -1, 2, 1, -5, 4 };
        vector<int> nums;
        Solution solution;
        Assert::AreEqual(6, solution.maxSubArray(nums));
    TEST_METHOD(TestMethod3)
        int numsArray[] = { -2 };
        vector<int> nums;
        Solution solution;
        Assert::AreEqual(-2, solution.maxSubArray(nums));
分类:代码挑战
