代码挑战: 最大子数组 #C#
Jet Ding 发表于 2021/07/23 16:15:27 2021/07/23
【摘要】 Given an integer array nums, find the contiguous subarray (containing at least one number) which has the largest sum and return its sum.Example:Input: [-2,1,-3,4,-1,2,1,-5,4],Output: 6Explanation: ...
Example:
Output: 6
Explanation: [4,-1,2,1] has the largest sum = 6.
方案:
    public class Solution
        public int MaxSubArray(int[] nums)
            int result = nums[0];
            int temp = nums[0];
            for(int i = 1; i < nums.Length; i ++)
                temp = Math.Max(nums[i], nums[i] + temp);
                result = Math.Max(temp, result);
            return result;
测试案例:
        [TestMethod()]
        public void Test1()
            Solution solution = new Solution();
            int[] nums = { -2, -3, 4, -1, -2, 1, 5, -3 };
            int result = solution.MaxSubArray(nums);
            Assert.AreEqual(7, result);
        [TestMethod()]
        public void Test2()
            int[] nums = { -2, 1, -3, 4, -1, 2, 1, -5, 4 };
            Assert.AreEqual(6, result);
        [TestMethod()]
        public void Test3()
            int[] nums = { -2 };
            Assert.AreEqual(-2, result);
