代码挑战:幸福数字 - C#
Jet Ding 发表于 2021/07/23 16:15:00 2021/07/23
【摘要】 Write an algorithm to determine if a number is "happy".A happy number is a number defined by the following process: Starting with any positive integer, replace the number by the sum of the squares ...
A happy number is a number defined by the following process: Starting with any positive integer, replace the number by the sum of the squares of its digits, and repeat the process until the number equals 1 (where it will stay), or it loops endlessly in a cycle which does not include 1. Those numbers for which this process ends in 1 are happy numbers.
Example:
Input: 19
Output: true
Explanation:
12 + 92 = 82
82 + 22 = 68
62 + 82 = 100
12 + 02 + 02 = 1
方案:
    public class Solution
        public bool IsHappy(int n)
            HashSet<int> hs = new HashSet<int>();
            while(!hs.Contains(n))
                hs.Add(n);
                int v = 0;
                while(n>0)
                    v += (int)Math.Pow(n % 10, 2);
                    n /= 10;
                n = v;
            return n == 1;
测试案例:
        [TestMethod()]
        public void Test1()
            Solution solution = new Solution();
            Assert.AreEqual(true, solution.IsHappy(19));
        [TestMethod()]
        public void Test2()
            Assert.AreEqual(false, solution.IsHappy(4));
        [TestMethod()]
        public void Test3()
            Assert.AreEqual(false, solution.IsHappy(123));
