代码挑战:找到单一数字-C#
Jet Ding 发表于 2021/07/23 16:14:35 2021/07/23
【摘要】 Given a non-empty array of integers, every element appears twice except for one. Find that single one.Note:Your algorithm should have a linear runtime complexity. Could you implement it without usi...
Note:
Your algorithm should have a linear runtime complexity. Could you implement it without using extra memory?
Example 1:
Input: [2,2,1]
Output: 1
Example 2:
Input: [4,1,2,1,2]
Output: 4
方案1:
    public class Solution
        public int SingleNumber(int[] nums)
            int result = nums[0];
            for(int i = 1; i < nums.Length; i ++)
                result ^= nums[i];
            return result;
方案2:
            HashSet<int> hs = new HashSet<int>();
            for (int i = 0; i < nums.Length; i++)
                if(hs.Contains(nums[i]))
                    hs.Remove(nums[i]);
                else
                    hs.Add(nums[i]);
            return hs.First();
测试案例:
        [TestMethod()]
        public void Test1()
            Solution solution = new Solution();
            int[] nums = { 2, 2, 1 };
            Assert.AreEqual(1, solution.SingleNumber(nums));
        [TestMethod()]
        public void Test2()
            int[] nums = { 4, 1, 2, 1, 2 };
            Assert.AreEqual(4, solution.SingleNumber(nums));
