代码挑战: 最大子数组 | Go
Jet Ding 发表于 2021/07/23 16:10:03 2021/07/23
【摘要】 Given an integer array nums, find the contiguous subarray (containing at least one number) which has the largest sum and return its sum.Example:Input: [-2,1,-3,4,-1,2,1,-5,4],Output: 6Explanation: ...
Example:
Output: 6
Explanation: [4,-1,2,1] has the largest sum = 6.
方案:
func maxSubArray(nums []int) int {
    result := nums[0]
    temp := nums[0]
    for i := 1; i < len(nums); i++ {
        temp = int(math.Max(float64(nums[i]), float64(nums[i]+temp)))
        result = int(math.Max(float64(temp), float64(result)))
    return result
测试案例:
func Test_maxSubArray(t *testing.T) {
    type args struct {
        nums []int
    tests := []struct {
        name string
        args args
        want int
        {"test1", args{nums: []int{-2, -3, 4, -1, -2, 1, 5, -3}}, 7},
        {"test2", args{nums: []int{-2, 1, -3, 4, -1, 2, 1, -5, 4}}, 6},
        {"test3", args{nums: []int{-2}}, -2},
    for _, tt := range tests {
        t.Run(tt.name, func(t *testing.T) {
            if got := maxSubArray(tt.args.nums); got != tt.want {
                t.Errorf("maxSubArray() = %v, want %v", got, tt.want)
