代码挑战: 最大子数组 | javascript
Jet Ding 发表于 2021/07/23 16:09:27 2021/07/23
【摘要】 Given an integer array nums, find the contiguous subarray (containing at least one number) which has the largest sum and return its sum.Example:Input: [-2,1,-3,4,-1,2,1,-5,4],Output: 6Explanation: ...
Example:
Output: 6
Explanation: [4,-1,2,1] has the largest sum = 6.
方案:
var maxSubArray = function(nums) {
    let result = nums[0];
    let temp = nums[0];
    for (let i = 1i < nums.lengthi ++) {
        temp = Math.max(nums[i], nums[i] + temp);
        result = Math.max(tempresult);
    return result;
测试案例:
  it("test1"function () {
    // 1. ARRANGE
    let nums = [-2, -34, -1, -215, -3];
    // 2. ACT
    var result = maxSubArray(nums);
    // 3. ASSERT
    expect(result).to.be.equal(7);
  it("test2"function () {
    // 1. ARRANGE
    let nums = [-21, -34, -121, -54];
    // 2. ACT
    // 3. ASSERT
    expect(result).to.be.equal(6);
  it("test3"function () {
    // 1. ARRANGE
    let nums = [-2];
    // 2. ACT
    // 3. ASSERT
    expect(result).to.be.equal(-2);
评论(0
