代码挑战:幸福数字 - Javascript
Jet Ding 发表于 2021/07/23 16:05:51 2021/07/23
【摘要】 Write an algorithm to determine if a number is "happy".A happy number is a number defined by the following process: Starting with any positive integer, replace the number by the sum of the squares ...
A happy number is a number defined by the following process: Starting with any positive integer, replace the number by the sum of the squares of its digits, and repeat the process until the number equals 1 (where it will stay), or it loops endlessly in a cycle which does not include 1. Those numbers for which this process ends in 1 are happy numbers.
Example:
Input: 19
Output: true
Explanation:
12 + 92 = 82
82 + 22 = 68
62 + 82 = 100
12 + 02 + 02 = 1
方案:
var isHappy = function (n) {
  let set = new Set();
  while (!set.has(n)) {
    set.add(n);
    let v = 0;
    while (n > 0) {
      v += Math.pow(n % 102);
      n = Math.floor(n / 10);
    n = v;
  return n == 1;
测试案例:
describe("isHappy()"function () {
  it("test1"function () {
    // 1. ARRANGE
    let num = 19;
    // 2. ACT
    var result = isHappy(num);
    // 3. ASSERT
    expect(result).to.be.equal(true);
  it("test2"function () {
    // 1. ARRANGE
    let num = 4;
    // 2. ACT
    // 3. ASSERT
    expect(result).to.be.equal(false);
  it("test3"function () {
    // 1. ARRANGE
    let num = 123;
    // 2. ACT
    // 3. ASSERT
评论(0
