代码挑战: 最大子数组 | Rust
Jet Ding 发表于 2021/07/23 15:55:10 2021/07/23
【摘要】 Given an integer array nums, find the contiguous subarray (containing at least one number) which has the largest sum and return its sum.Example:Input: [-2,1,-3,4,-1,2,1,-5,4],Output: 6Explanation: ...
Example:
Output: 6
Explanation: [4,-1,2,1] has the largest sum = 6.
方案:
impl Solution {
    pub fn max_sub_array(nums: Vec<i32>) -> i32 {
        let mut result = nums[0];
        let mut temp = nums[0];
        for (_pos, e) in nums.iter().enumerate() {
           temp = std::cmp::max(*e, *e + temp);
           result = std::cmp::max(temp, result);
        return result;
测试案例:
    #[test]
    fn test1() {
        let vec = vec![-2, -3, 4, -1, -2, 1, 5, -3];
        let result = Solution::max_sub_array(vec);
        assert_eq!(result, 7);
    #[test]
    fn test2() {
        let vec = vec![-2, 1, -3, 4, -1, 2, 1, -5, 4];
        assert_eq!(result, 6);
    #[test]
    fn test3() {
        let vec = vec![-2];
        assert_eq!(result, -2);
